Interior/Exterior HOw to remove front bumper skin?
Old Jan 28, 2006 | 11:19 AM
Kendel72's Avatar
Kendel72
I am installing a middle M7 ultimate grill, I need to either remove the front bumper or just skin. What is involved?
Old Jan 28, 2006 | 11:25 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
There are three 10mm bolts under the front bumper that attach to the skidplate area, there are two phillips head screws to the sides of these 10mm bolts that attach to the fender liner, two T30 torx head bolts on the top of the cover, and two vertical 8MM bolts that are easiest to remove using a 1/4" ratchet with a long extension and an 8mm socket.
Hope that helps!
Randy
Old Jan 28, 2006 | 11:29 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
The T30 torx bolts:
One of the three 10mm underside bolts:
The 8mm bolt:
BTW - the sizes for the bolts I used are the socket size.
Hope that helps!
Randy
Old Jan 28, 2006 | 11:41 AM
Johnna's Avatar
Johnna
PS to Randy's great write up / picture esay. Wish I'd seen it before doing mine! It helps to **** the front wheels to one side or the other.
Old Jan 28, 2006 | 11:50 AM
Kendel72's Avatar
Kendel72
One thing I cant tell in the pisture, on the middle grill you have a chrome piece that comes out and a painted piece that looks as if it stays in, do you remove the painted piece?
Old Jan 28, 2006 | 11:56 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
The whole thing comes out.
Johnna's Avatar
Johnna
If I understand you correctly, you are talking about the lower part of the grill with chrome trim around the grill slat. If so, you'll find that when you remove the chrome suround,the painted grill slat comes out with it.
Old Jan 28, 2006 | 12:09 PM
Kendel72's Avatar
Kendel72
Mine didnt, I got the chrome piece and the painted plact piece stayed in, I just pry'd it off and 3M two sided tape was holding it on and it is going to be a BIO*&& to get off.
Old Jan 28, 2006 | 12:10 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Use some "Goo Gone" and it should take off the stocky stuff. You must have a newer car, eh?
Randy
Old Jan 28, 2006 | 12:11 PM
Johnna's Avatar
Johnna
Yep, the double-stick tape is a royal pain. Razor blade and some Goof-off worked for me.
kapps's Avatar
kapps
When you put it back on, make sure you use to adjustment screws (the one's in the fender) to get the right clearances. Just screw them in until they stop then back them off. The carrier is spring loaded so you can push it around to align it.
Old Jan 28, 2006 | 12:25 PM
Kendel72's Avatar
Kendel72
Thanks guys and especially you Randy!
Old Jan 29, 2006 | 06:33 AM
Johnna's Avatar
Johnna
Kendal,
We're waiting for a picture of the final product!
Old Jan 29, 2006 | 06:39 AM
pooch1's Avatar
pooch1
Yes we want pictures.
Old Jan 29, 2006 | 12:38 PM
Kendel72's Avatar
Kendel72
I will try to ost pictures afterwhile, I opted to just take my Dremel and cut out the two sections that had the two sided tape on the and that presented a visual problem. The aluminum bumper will be seen so now I am polishing it which is a pain in the butt and then I will reinstall the cover! Hoe all comes out well.
Old Jan 29, 2006 | 07:14 PM
Kendel72's Avatar
Kendel72
[IMG][/IMG]
Here is a couple pics of final!
Old Jan 29, 2006 | 07:28 PM
Kendel72's Avatar
Kendel72
[IMG][/IMG]
Old Jan 29, 2006 | 09:01 PM
kyriian's Avatar
kyriian
a more further away shot would be nice! but im desperately waiting for my black one to come in....
Old Jan 30, 2006 | 05:50 AM
62Lincoln's Avatar
62Lincoln
Old Jan 30, 2006 | 09:24 AM
Kendel72's Avatar
Kendel72
[IMG][/IMG]
here ya go further away!
FLYM1N1
Aug 15, 2015 11:20 AM
smlzilla
Aug 14, 2015 07:00 PM
JHolland
Aug 13, 2015 10:47 PM
skippermini
Aug 12, 2015 10:05 PM
