Interior/Exterior M7 Grill Install?
Old Jan 27, 2006 | 01:51 PM
Kendel72's Avatar
Kendel72
M7 Grill Install?
Have any of you had any problems installing the upper grill? The original grill has plastic nuts and they wont come off so most broke and the M7 grill brackets so far are not lining up good. Any experience?
Old Jan 27, 2006 | 02:17 PM
J0kER's Avatar
J0kER
the holes are a tight fit they will line up tho, the bolts that came w/the kit were to short for me so i got sum longer ones at Home chepo......they were not much longer, jus enough to get the hole on the grill to line up.
Old Jan 27, 2006 | 02:28 PM
JustinO's Avatar
JustinO
I found the best way was really with a little help from another person. One to hold the grill in place and hold the nut with a pair of needle nose pliers. And the second person to turn the screw.
It takes a bit of time. I would lay a towel or blanket over the engine, i dropped a bolt when doing this, and learned the hard way trying to find the darn thing.
The grills look great when done.
Old Jan 27, 2006 | 06:50 PM
Kendel72's Avatar
Kendel72
You are exactly right about the longer screws, I fought that thing for about 25 minutes and then decided to go by longer ones then it took me 5 minutes!!! No sense what so ever, do you have to take the whole front bumper off to install the middle grill?
Old Jan 27, 2006 | 07:16 PM
Wagnbat's Avatar
Wagnbat
Taken out of context, and it becomes quite funny.
Old Jan 28, 2006 | 06:41 AM
JustinO's Avatar
JustinO
Yea yea yea, i knew i was getting into trouble with that one.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Aug 7, 2015 05:56 AM
