Interior/Exterior Foam injection into frame ?
Old Dec 2, 2005 | 12:39 PM
  #26
OldRick's Avatar
OldRick
I think that there are probably a lot more places in a Z.
I just did the four box-sections that support the floorpan and lead up into the firewall a few inches. I wound up with about 1/2 of a kit left, and 3-4 cups-worth on the floor. If the car were bare to the frame, I'm sure you could spot some other useful spaces to fill, but I just did the easy ones.
The only tip I can offer is to start with an 8" hose in the deepest part at one end (fill from the bottom to let the air out), then move from hole to hole as the foam appears along the length. When you get to the other end, stick the hose in the blind end to fill from the bottom again.
The other tip is; plan where you will move as you fill the sections - you don't want to move under a still-oozing hole.
Old Dec 2, 2005 | 01:17 PM
  #27
mp5999's Avatar
mp5999
man your right there- I definately " don't want to move under a still-oozing hole." haha, sorry , I couldnt resist that one.
Its a shame I didnt do this before, about 2 months ago the car was totally stripped down to the bare frame, actually it even got a complete new right front frame rail section put on.
thanks again for your ideas
Old Dec 25, 2005 | 08:21 AM
  #28
OldRick's Avatar
OldRick
I'd be curious to compare notes with anyone else who has foamed their MINI. Anyone else try this?
Old Dec 25, 2005 | 08:59 AM
  #29
SpiderX's Avatar
SpiderX
are there any stats on off-gas from the foam...... will you grow funny parts...... a lot of tha stuff has strange properties........ other than that i would love to get my ride even quieter.......
Old Dec 25, 2005 | 10:27 AM
  #30
OldRick's Avatar
OldRick
It's a closed-cell foam, so there shouldn't be any gasses emitted during curing or later. Also, it's outside the car and enclosed in metal except for a few small holes, so I don't think I'd worry about that too much...
Old Jan 3, 2006 | 11:45 PM
  #31
J0kER's Avatar
J0kER
D I T T O
anyone ?
Old Jan 4, 2006 | 10:32 AM
  #32
Dr Obnxs's Avatar
Dr Obnxs
I'll be doing it sometime.
Originally Posted by joker
anyone ?
But not until it's much more dry... And with the rain in CA, that may not be for a while....
Matt
Old Jan 4, 2006 | 11:32 AM
  #33
J0kER's Avatar
J0kER
right~0n
same here!! between the cold & the rain cant do to much right now.
note to self:
__need to get that 63bug out of my garage so i can werk in it
Old Jan 4, 2006 | 03:13 PM
  #34
Wagnbat's Avatar
Wagnbat
What about moisture trapped between the foam & metal when it does rain/snow and/or get humid? Wouldn't that increase the rate of corrosion? Those holes you're filling through may be there intentionally to both keep water from building up in those voids, and to keep those voids ventillated.
Old Jan 4, 2006 | 05:09 PM
  #35
J0kER's Avatar
J0kER
have gave it sum thought but......
i dont think i'll be keepin' the car long enough to worry bout that
also if its done correctly that foam gets in all the spaces as it expands so u have to werk fast and use a lot of product.......careful plannin' is key w/this kinda stuff.....
are u goin' to do it?
Old Jan 4, 2006 | 05:11 PM
  #36
Wagnbat's Avatar
Wagnbat
Don't think so. I think the Batmini is a car I want keep.
Old Jan 4, 2006 | 05:12 PM
  #37
Dr Obnxs's Avatar
Dr Obnxs
It's a closed cell foam..
So if you put it in dry, the surfaces it bonds too will stay dry. If you put it in with moisture in there, it won't get out. At least not fast. Hence my desire to wait until it's dry, and has been warm for a bit...
Matt
Old Jan 4, 2006 | 05:34 PM
  #38
Wagnbat's Avatar
Wagnbat
True, but are you going to fill the void 100%? Any chance of moisture getting into any pockets from the top and not being able to escape?
And also being closed cell, the cells may not create a well sealed 'bond' evenly over the surface. Kind of like how a bag of marbles I'm thinking. They'd probably bend and flex to themselves real well, but I'd suggest doing a test first. Better safe than sorry, eh?
Old Jan 4, 2006 | 05:38 PM
  #39
J0kER's Avatar
J0kER
also forgot to mention...
if its at all like the stuff i've used in the past its an oil base like product so it would make it even more water proof in thereto if the car where ever to fall in a pond it would floateasier to retrieve.....okay im out of resonable stuff to say ill be goin' now
Old Jan 4, 2006 | 05:41 PM
  #40
Dr Obnxs's Avatar
Dr Obnxs
Not really...
Marbles don't compress. Foam bubbles are a whole lot more conformal. As for moisture from the top, it's possible, but you can put the foam in pretty much anywhere water can get.
Go ahead, take a little risk! Also, look at some of the new cars and SUVs. They're coming stock with foam injection into parts and voids, as the lazy pansy-assed culture is demanding 4x4 SUVs with so little roadnoise you can hear a knat fart.
Matt
Old Jan 4, 2006 | 05:43 PM
  #41
J0kER's Avatar
J0kER
sorry i took to long to type my last reply didnt see ur last reply, anywho!
its not likely this will happen cuz this stuff really fills out and expands like crazy, it will find any hole/space and fill it w/product it keeps expandin' till its completely dry which takes a while
Old Dec 1, 2010 | 09:25 AM
  #42
ggcadc's Avatar
ggcadc
this is an old thread, but I'm looking into this, any new news on this, and also, the product mentioned early on in the thread is $500??? somehow that cant be right, maybe the link isnt working right. any new info would be appreciated.
Old Dec 10, 2010 | 11:32 AM
  #43
ECHO-313's Avatar
ECHO-313
+1
Could you just use the stuff that comes in a can from Home Depot?
Any more reviews?
Old Dec 10, 2010 | 12:13 PM
  #44
ggcadc's Avatar
ggcadc
from what ive read it's clear that the tripple expanding foam from home depot would not work, it needs more rigidity and the stuff that would work is a poly foam. hope someone can chime in that has done this or some experience with it.
Old Dec 10, 2010 | 12:56 PM
  #45
ggcadc's Avatar
ggcadc
this might work?
http://www.google.com/products/catal...d=0CHAQ8wIwAA#
IQRaceworks
53
Jun 28, 2024 07:29 AM
shadtree
Cooper (non S)
Sep 8, 2016 12:02 PM
buggyeye401
Oct 1, 2015 01:22 PM
Samhillrocks
Sep 29, 2015 12:55 PM
buggyeye401
Sep 28, 2015 04:09 PM
