Interior/Exterior Parcel Tray Install in 2006 MCS
Old Nov 8, 2005 | 06:30 AM
headhog1's Avatar
headhog1
I'm having a problem installing the Parcel Tray in my 2006 MCS.
The original lower panel in my MCS has 3 pivot points. The instructions that came with the parcel tray, and the instructions I found on NAM, imply there are only 2 pivot points. After rotating the bolster panel down, you are to gently "lift" it out. It is impossible to lift mine out because the center pivot point is cupped opposite the outside two pivot points. To release the center pivot point it appears you have to press it down. Or perhaps, you just have to pull like heck straight out (towards the back of the car) to remove it. I'm not too comfortable with pulling like heck. I've already pulled more than I'm cofortable. It is bending the other plastic pieces in dash.
Has anyone with a 2006 MCS installed the Parcel Tray?
Old Nov 8, 2005 | 07:09 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
they all have three tabs. once the big pull to make it swing down is done. pull out the tab that is closest to the door. then, with a slight twisting down motion, pull down and back and it should pop out of there. i have installed at least 10 to 15 of them and it always feels like it's going to snap, but it never does. but even if it does, you will never see it or need it for the new part. and most likely you will not be reinstalling the old part. so go for it, give it a yank. hope this helps, give me a call if you need more.:smile:
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Nov 8, 2005 | 07:23 AM
dave's Avatar
dave
pug poo picker-upper
AFAIR, my '02 only had two pivots, but when I installed the Euro shelf on a friends '05 it had three. Like Chad said, just give it a good tug.
Old Nov 8, 2005 | 07:43 AM
headhog1's Avatar
headhog1
Everything is easy once you know how to do it. Thanks
Old Nov 9, 2005 | 03:37 PM
TrippleBeem
I JUST installed mine, i just pulled the original part down, lifted a little and it came right out... this prolly doesnt help you and is kind of annoying, but it came right out...
Ryan
Old Nov 9, 2005 | 04:01 PM
sagworks's Avatar
sagworks
running with scissors
I installed mine the day after getting my '06. It took A LOT of force to get out. Use more force than you think you'll need to and it should come out. I don't remember how many pivot points there were, but the shelf went in pretty easy - hardest part was getting the bolster out. :smile: it is worth it, a great add-on!!!!
squawSkiBum
Oct 2, 2015 09:21 AM
keck.j
Aug 18, 2015 08:18 PM
minipopkart
Aug 13, 2015 05:22 AM
