Interior/Exterior Blue Dash Lights
Yes, if I'm not mistaken, the new Mustang has something like over 200 colors you can change your dash guages to...
I think one of those Scions (or all of them) also offer guage color changing capability too.
'Twould be cool, if MINI offered it.
Originally Posted by uber s
Well, I have finally joined the blue dash club. I followed BluMiniMe's how-to, and everything turned out great! I left the needles and computer displays amber, so during the day you can't tell that anything's different. But at night, it looks sweet! Only one problem: the LED's for the radio and MFSW are different than the rest. Does anyone know a part number for these? I didn't have any luck with the Digikey part numbers, so now I'm kinda stuck with a half-finished job. Can anyone help me?
.@Wagnbat: He said "BZ" LOL. Thanks shipmate!
Thanks, BluMiniMe - your how-to was very helpful
. I emailed Allied Electric yesterday, and they're sending some sample led's to try to help me find the right one. I'll give the digikey ones a go if none of the samples work out, but since Allied was so helpful, I'm gonna try to stick with them. Also, the '05 MFSW led's are the same size as the radio's. If the small(er) led's from Allied work, I'll post the part numbers as soon as I can.
By the way... are your gas/water temp gauges a little purple? I've got some bleedover coming from the needles/red warning led's and it 's kinda the only tarnished spot on an otherwise clean look.
My pleasure, UberS.
G'luck with the radio and MSFW.
I tried 3 times to find a way into the climate control ****-- the big round one, and I just couldn't do it without desoldering significant other pieces. I was afraid it wouldn't work once I did. So, my dash has an orange ball with blue wings.
Not a bad look.
I do get a little purple bleed over at the temp and fuel needles. The white plastic guage face piece doesn't have enough shroud in that area to keep the blue and red needle LEDs from bleeding together. I had an idea for super-glueing some plastic in there to shroud them better, but I'm too lazy.
Except for the time factor, I thought overall, this wasn't too hard. A little patience and the right tools made it a breeze-- good weekend project while its snowing outside! You?
Not a bad look.I do get a little purple bleed over at the temp and fuel needles. The white plastic guage face piece doesn't have enough shroud in that area to keep the blue and red needle LEDs from bleeding together. I had an idea for super-glueing some plastic in there to shroud them better, but I'm too lazy.
As far as the AC goes, I didn't take the climate control **** apart either. I wanted all of the little text displays (odometer, OBC, radio, AC) to stay orange. It kinda goes along with the needles, IMO. Also, I wasn't able to come up with a filter that could let enough (blue) light through without spotlighting from the LED's. I also replaced the little green LED's on the AC buttons with leftover orange ones (didn't want too many colors on my dash). The orange LED's are a little too bright though, so next time things are apart, I'll find a way to dim them down a bit.
I didn't have the right LED's for the waterfall lighting, but I was able to rig the blue LED's (AND6BB's from allied) to work. I still need to replace the flat tire reset LED and the door handle LED's. And while everything else is apart, I'll see what I can do with the purple bleed over problem. Super glue and plastic ain't a bad idea...
All in all, I think this was really easy. Once I had the soldering technique down and the right tools (I didn't know that a T6 torx even existed!), things went smoothly. Definitely a good weekend project, but I wouldn't know about the blowing snow...(note location!
Originally Posted by Sarcux
Good to see someone else finally is stepping up and doing this too! I seemed to be one of the only ones for the longest time...
EDIT: I didn't speak to this, and I don't think the how-to's do either. What filtering element did I use in the text windows? I experimented with different layers of plain old wax paper. When I found a balance between the "spotlighting" and daylight visibility, that's what I used. I don't recall exactly, but I think I settled on 9 layers? Not sure.
Yup, that's mine. Glad people are still getting use out of it. I'dnever soldered before that, and didn't have much trouble - which makes me surprised that more people haven't done it. Oh well - maybe I can get it published in MC2 magazine, hehe.
Originally Posted by CyebrOgre
That looks great! I may have missed it, but how did you do the lights for the Climate Control system?
The second linked Word document is wonderful and also shows how to open up the dash board AND the gauges- both are things that are usually not documented in Mini's official How-to instructions (they usually reference other dealer service articles, most of which are difficult to find). There are several add-on parts, both OEM and aftermarket, that require a dashboard removal, and now I know how- thanks!
This is a MOD that's not for the faint of heart, but it IS hella cool. Maybe one day...
minicoclub
Nov 11, 2015 07:25 AM
Navigation & Audio MINI Branded nuvi 360 Installation
Super Coop
Aug 17, 2015 05:09 PM
Powershift
Aug 16, 2015 05:14 PM
