Interior/Exterior Painting Headlight Housing (aka Joey Mod)
#26
Originally Posted by chikmagnet
i was just looking at the pic of the dissasembled headlight and it looks very similiar to my 05 xenons as far as how they are put together any insight in to this. I know thats what this thread is all about but any insight will be helpful as i will probably try to do this next week
first i will explain what each thing is...or atleast a quick explanation. From left to right. The black boxes are for the xenons, the bigger one being the ballast. To the right of that is the chrome housing, its the reflector housing that projects the light outwards (this part wouldnt be painted, it needs to stay reflective). the black plastic part is the backing plate of the entire assembly, you can see it on the inside of your hood. Underneath that is the chrome housing (the part you would paint) still connected to the outer lense. And lastly on the right end side is the chrome surround which goes on top of the lense via clips which is easily removable(and can be purchased separately.
Now....using those names, i will explain how things go together (as far as i know).
-The reflector housings plug into the back of the chrome housing (the bulbs go into the reflector housings).
-The chrome housing is sealed to the clear lense via a liquid sealant. The sealant is the part that you have to heat up in order to remove. There are some people who have stated that there are clips also associated with this connection.
-This combo of reflectors,chrome housing, and lense are all placed into the black plastic backing. By what means, i dont know. I wish it was just screws, but i highly doubt it. It almost looks like it was cut off in that pic....but i dont know
-The ballast and igniter for the xenons then attach to the black plastic backing plate on the outside.
-The chrome surround clips onto the lense hiding the connecting points for all the other parts.
-The entire unit is held on the car via some screws (nothing hard interms of this removal
This is discussing the 02-04 xenon housing pictured above. A lot of the connection methods are unkown. I am using knowledge of other car headlights and various pictures i have seen to SPECULATE about some of the above information. I may be wrong.
#31
#32
#33
#35
Originally Posted by ariercetinberk
how about the carbonfibre? How do I do it?
rough up the chrome with some sandpaper. Make sure its rather textured. Apply a thin layer of your choice of resin. Lay down a layer of carbon fiber fabric on the area and make sure its absolutely flat and tight. Brush on a bit more resin, Allow to cure. Sand with finer and finer grit sandpaper. Cover in some sort of UV protectant (pro's differ on choice here). Trim all the edges so they are the same as the actual housing. Admire your work.
That is a very abridged version of the process. And most people are unable to make a successful overlay on their first attempt. You can have lots of problems between bubbles, discoloration, and uneven surfaces...all dependent on the above processes. I would like anyone attempting to do this to do way more reading. I'm just putting this out there to give a little glimpse into the process.
#39
Originally Posted by IanF
Hmmm... we have an extra '03 Xenon headlight (w/ broken lens from a re-tread) in the attic... this looks like a good Winter project.
Yes it is
I ask that anyone who does this please take pictures for the rest of the community. This will be one of my many winter projects this year (and maybe some academic work will be done too ). I will take comprehensive notes and write up a how-to....even if it doesnt work as expected i will let you guys now . I have some other secret plans for the headlight as well
#40
Originally Posted by RallyMINI
Yes it is
#42
#46
Originally Posted by WeeGas
It has been almost four months since the last mention of this....has anyone tried to do it as their winter project yet? RallyMINI???
I know of atleast 2 people. 2 of my M|U Teammates just managed to get a great deal on some headlights on ebay.....they are now working to get them open. Pictures and a how-to will be available if they are sucessful.......
I encourage anyone to try and let us know how it goes.....i really wanna open it up and see what i can do. I have some plans
#48
on
There is a guy here in are utah mini club that has done this, he is going to help me get mine apart, he said he had to break around some tinny bolts, not sure how bad but he said you cant see it and it went back togeather with no problem he said now the has done one, the second one will be very easy to do! I think that electic blue in the head light would look sweet!!
#49
I'm looking for a pair or even just one side of the 05 xenon headlamps.
If you guys know of any for a really good deal, please email me at jonsibal@***.net. Thanks
