Interior/Exterior B&M Short Shifter installed
Jul 6, 2005 | 11:27 AM
Like the throw a lot! But it's a little harder to shift. Was wondering if anyone else installed it and if they have the same issue.
Jul 6, 2005 | 12:20 PM
It is a little stiffer but you will get used to it quickly and the benefit far outweighs the stiffness.
Jul 6, 2005 | 12:26 PM
Thanks, I thought it was just me.
Jul 6, 2005 | 03:16 PM
i have the alta short shift, i can really tell the difference in force needed to shift if when i adjust it from stock height to shortest height. i think your ok.
Jul 6, 2005 | 03:26 PM
Add a heavier ****, such as a whalen, and it will help with the shifting
Jul 6, 2005 | 03:34 PM
It'll loosen up after the first few days, too.
Jul 6, 2005 | 04:46 PM
Quote:
Its physics, you're moving the linkage the same distance w/ less hand motion
Jul 7, 2005 | 08:28 AM
right. you're using a shorter lever so more force is required.
Anyways, did your car have a center resonator for the exhaust? if so, any issues installing it?
Jul 7, 2005 | 08:32 AM
i have a Quicksilver exhaust so no resonator. I had help with the install and it went smoothly.
W0TM8
Dec 19, 2019 07:50 AM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
