Interior/Exterior Driving lamps installed - BUT DON'T WORK!?!
Old Apr 20, 2005 | 04:00 PM
mrdirosa's Avatar
mrdirosa
I installed my MINI driving lamps last night, following the directions exactly (except the fuse box and ground bolt in the hood). I went to try them and they don't work. The switch doesn't even arm.
Completely dead...
I'm not sure I put the two black ground wires on the right bolt in the hood. It's a bolt on the driver side that has a wire from the hood connected to it. Not sure if that is a ground bolt or not.
BC1 connection and radio connections are all fine, and the lights are wired correctly so I have no idea where else to look!
Help please!
Old Apr 20, 2005 | 04:27 PM
rataha's Avatar
rataha
has the dealer activated them?????
Old Apr 20, 2005 | 04:34 PM
mrdirosa's Avatar
mrdirosa
Nope
Dealer doesn't need to activate them do they? The directions say that they don't have to. Only the european driving lamps need activation.
Old Apr 20, 2005 | 04:46 PM
Eric_Rowland's Avatar
Eric_Rowland
Unless they are directly wired, you probably need the dealer to tell the BC1 that you have the driving lights.
Old Apr 20, 2005 | 04:52 PM
MINI Monkey's Avatar
MINI Monkey
The dealer doesn't need to activate them. I would check all connections again, especially the ground and the quick connectors. The factory driving lights only work with the high beams on if you wire them to oem specs.
Old Apr 20, 2005 | 04:56 PM
MINI Monkey
Maybe try a different bolt to use as a ground.
Old Apr 20, 2005 | 04:58 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
mrdirosa, did you try them with your high beams? I know it sounds simplistic, but give it a try! Good luck! :smile:
Clover
Old Apr 20, 2005 | 05:45 PM
kenchan's Avatar
kenchan
Use one of the strut mount bolt/nut as your ground.
Old Apr 20, 2005 | 06:06 PM
mrdirosa's Avatar
mrdirosa
Tried using one of the strut tower bolts as the ground and still nothing. Yup, I know they only work with the high beams...
Made an appointment with the dealer for next friday, but if I can figure this out myself it would be better than paying them X hundred dollars to do it.
Thanks!
Old Apr 20, 2005 | 06:10 PM
mrdirosa's Avatar
mrdirosa
Any clue on why the switch won't even arm? even if the lights do not power up, shouldn't the switch light up when pressed? Where does the power to the switch come from?
Old Apr 20, 2005 | 06:42 PM
kenchan's Avatar
kenchan
Is this the factory one? if so, don't u have to have it programmed?
If aftermarket, you should be able to tap the lead to one of the
switched fuses and be able to turn it on even without the highbeams.
It sounds like you don't have power going to the switch to power the
relay.
Old Apr 20, 2005 | 07:22 PM
MINI Monkey
The switch lights up when the interior lights are on. I didn't take mine the the dealer to have it programed. Their has to be something hooked up wrong. Are you sure you connected the wire that goes over to the passager footwell to the right color wire. I would retrace all the wire one more time. check all the colors and connections again. It would be a shame to get this far and have to take it to the dealer.
Old Apr 20, 2005 | 10:59 PM
mrdirosa's Avatar
mrdirosa
Yes, all wires are correctly connected to the right wires (I even checked the pin numbers on the source wires).
I wonder if I have a bad switch?
Old Apr 21, 2005 | 08:31 PM
MINI Monkey
If all your wires are hook up right, I would think a bad switch is a good theory.
Sorry I couldn't be more help.
Old Apr 29, 2005 | 02:48 PM
mrdirosa's Avatar
mrdirosa
Fixed!
Took it to the dealer today and they fixed it after an hour and a half - evidently one of the quick connectors did not "connect" all the way on the back of the radio.
$51 later they work!
to Ralph Schomp MINI in Denver
Old Apr 29, 2005 | 06:18 PM
MINI Monkey
That's Good, I'm glad you got them working.
1chaos52
Aug 24, 2015 01:28 PM
DWooderson
Aug 10, 2015 09:12 AM
Lt. Dan
Aug 10, 2015 08:23 AM
