Interior/Exterior Visor Sticker Removal Directions!
Old Jun 23, 2005 | 01:59 PM
  #26
SRTech's Avatar
SRTech
I can't believe the visors themselves would be any different. In the past, Europe made you be responsible for knowing what's dangerous or not. I'm sure that's changing, but hopefully they don't put warning labels on everything, yet.
Old Jun 23, 2005 | 05:28 PM
  #27
fdavid's Avatar
fdavid
I'll talk to my brother in law back in Barcelona to check for me. I'll let you guys know about this pretty soon.
Old Jun 23, 2005 | 05:33 PM
  #28
SRTech's Avatar
SRTech
Thanks, I would rather have perfect ones since it seems like there is not a 100% chance of complete and invisible removal of those really ugly stickers.
Steve
Old Jun 23, 2005 | 05:51 PM
  #29
not-so-rednwhitecooper
Originally Posted by eMINI
My dealer quotes $52 for new visor and verifies that it will come with the sticker
Maybe we could just put a less objectionable sticker over it or to cover less than ideal results. Any suggestions?
heres one!
Old Jun 27, 2005 | 07:32 AM
  #30
tattman23
Originally Posted by SRTech
Is it possible that the European version visors don't come with the sticker?
Be sure, if you go this route, that you specify that you don't want the RHD (right-hand drive) sunvisors!
Old Jun 28, 2005 | 06:38 AM
  #31
cooper37's Avatar
cooper37
less objectionable?
I know you are trying to be...ummmm...funny but, I find your suggestive sticker far worse and yes, objectionable and misogynistic, than the OEM decal.
Old Jun 28, 2005 | 03:02 PM
  #32
you guys need to lighten up a bit and laugh more!
Old Jun 28, 2005 | 03:18 PM
  #33
minimonkeygrrl's Avatar
minimonkeygrrl
The Denatured alcohol is so easy. Don't bother with all those steps. I did mine in 10 minutes. Take two paper towels, fold in four, soak with denatured alcohol and then hold against the sticker for 30 seconds, the alcohol evaporates quickly so put some more on the folded towels and hold on the sticker for at least another 30-60 seconds. Then gently move the towel across the sticker and it will just roll off. If it does not just hold the soaked towel a little longer and it will. Don't force the sticker or it will end up in tiny little bits like above complained about. It is very easy, just have a lil patience. There have a been a million threads and it has been determined this is the best way. Oh and there is a little sign of it being there if you get it in just the right light at an angle. GOOD LUCK.
Old Jun 28, 2005 | 03:40 PM
  #34
Sarcux's Avatar
Sarcux
I just grabbed a shop rag and some acetone, visors still in the car, and scrubbed for a few minutes. Wham Bam, Thank You England! Came right off.
Old Jul 4, 2005 | 12:13 AM
  #35
J0kER's Avatar
J0kER
nice bit !!!!!!!
where oh where can i get some of these?
they rock!!!!!!!
& yes..... we must lighten up.
do u know, is it the same size as de' one allready there?
Originally Posted by rednwhitecooper
heres one!
Old Jul 4, 2005 | 02:37 PM
  #36
Americonium's Avatar
Americonium
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Maybe a bit less um, objectionable?
Old Jul 4, 2005 | 04:05 PM
  #37
VRBeauty's Avatar
VRBeauty
Not to mention that it has a misplaced comma, which would distract & bother me to no end!
Old Jul 4, 2005 | 05:50 PM
  #38
hugh's Avatar
hugh
Suggested Solution
How I solved my visor warning sticker problem.
(until I get around to buying some denatured alcohol...thanks for the advice !!)
hs
Old Jul 4, 2005 | 08:18 PM
  #39
yes, this guy has them all, the sticker is about the same size too!!!!
Old Sep 6, 2005 | 07:24 PM
  #40
pure&simple's Avatar
pure&simple
I did the sticker removal on my 05 anthracite visors this past weekend using denatured alcohol. I actually tried Goof-off first, but found it was evaporating too fast to really soak the visors, although maybe I wasn't doing something right. Anyway, the longer you let the alcohol-saturated paper towel soak the visor, the less residue you'll have when you're done. You're not just trying to dissolve the adhesive - you're trying to dissolve the sticker itself. It should bubble up and have the consistency of a baby wipe when you peel it off, and it should come off in one piece if you peel gently and use something like a wood chisel to help it separate from the visor. I let mine soak for 40-45 minutes and resaturated the paper towel several times. I also put a little weight on top to keep the paper towel against the visor. Obviously the visors need to come off the car to do this. Don't worry too much about taping things off or hurting the material... it seems to be pretty durable stuff. Once I had the sticker off, I used a toothbrush to help remove some of the remaining residue, first using more alcohol and then soapy water. Got a tiny bit of improvement with this method, but not much. Overall, I'm pleased with the results. There is a subtle rectangle of residue that outlines where the sticker used to be, but you wouldn't really notice unless you were looking closedly.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
greekzilla
Aug 23, 2015 03:44 PM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
kvnadriano
Aug 10, 2015 08:48 AM
