Interior/Exterior S Wing
Old Jan 30, 2005 | 05:01 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
S Wing
I Have An 2004 Mini Cooper S ,with The Stock Spoiler, I Like The Look Of It With No Spoiler, Is It Hard To Get Off?, Does It Actually Help Downforce? And How Is It Held On? Does It Help Downforce Or Handleing?
Can I Have Some Pics With It Off? Thanks Abunch
Liljack And Matchbox
Old Jan 31, 2005 | 02:45 PM
littlehandegan
Bump it up!
liljack and matchbox
Old Jan 31, 2005 | 02:50 PM
MSFITOY's Avatar
MSFITOY
It's not hard to remove but it is a bit of work. There are two nuts that needs to be removed and then the adhesive needs to be "cut" with a 30# or greater fishing line. Then you need to remove the residue with 3M's adhesive remover or benzine prior to mounting the new wing. See my thread near the end. I removed the S wing and installed a CF Aero wing. Problem is that you want it left off but there are now two holes in the sheet metal
https://www.northamericanmotoring.co...566#post467566
Old Jan 31, 2005 | 02:51 PM
dave's Avatar
dave
pug poo picker-upper
I had my S spoiler removed and the aero kit spoiler installed (see the post stuck to the top of this forum about the different spoiler types).
The S spoiler is held on with double-backed tape and two threaded studs. The nuts for those studs are accessible when you open the hatch by removing the outer black plastic caps from the inside of the upper part of the hatch lid.
Once the S Spoiler is removed there will be two holes in your hatch lid that would need to be plugged and painted if you wanted to go bare. In my case the aero kit spoiler covered those holes up when it got bonded on to the top edge of the hatch.
Old Sep 12, 2005 | 03:16 PM
LAMINI's Avatar
LAMINI
did
I would interested in you stock cooper S spoiler if you still have it?
Old Sep 12, 2005 | 03:18 PM
dave's Avatar
dave
sorry, I sold it shortly after I had the aero kit spoiler put on.
Old Sep 12, 2005 | 03:19 PM
MSFITOY's Avatar
MSFITOY
I have one available if DiD doesn't :smile:
carid
Dec 28, 2025 04:11 AM
minimofo
Jan 26, 2016 11:32 PM
vetsvette
Oct 22, 2015 09:46 PM
BackcountrySkier13_inAZ
Oct 14, 2015 06:00 PM
vetsvette
Oct 2, 2015 05:32 PM
