Interior/Exterior Help Please-Gauge Install Question
Old Jan 23, 2005 | 04:08 PM
MINI Monkey's Avatar
MINI Monkey
Is it ok to use the same ground for multiple gauges and can I use the same power source connection for the lumination wire for two gauges? Thanks!
Old Jan 23, 2005 | 04:20 PM
eurekame's Avatar
eurekame
I would say yes. I just installed the under the toggle switch gauges last night. On these factory gauges Mini uses one ground for two gauge lights, voltmeter and the ground for the oil temp. The power for the lights is supposed to be taken from the back of the radio and supplies the power for both gauge lights. I found a light wire on the cigarette lighter power and tapped into that for the two under toggle gauge lights and a third gauge light as well.
Old Jan 23, 2005 | 04:35 PM
MINI Monkey
That's Perfect. Thanks for the quick reply.
Alkaidovich
Jan 30, 2021 01:35 AM
adrchn
Aug 13, 2019 02:11 AM
silence2-38554
Nov 12, 2015 09:39 AM
squawSkiBum
Oct 2, 2015 09:21 AM
