Interior/Exterior Moonroof Windnoise
Old Dec 14, 2021 | 04:07 PM
ctwang's Avatar
ctwang
Moonroof Windnoise
Anyone have a fix for the horrendous wind-noise associated with a 2013 ClubmanS' moonroof?
Old Dec 14, 2021 | 09:05 PM
chrunck's Avatar
chrunck
Have you tried closing it?
Old Dec 15, 2021 | 08:07 AM
Gubi's Avatar
Gubi
There are details somewhere (service manual? TSB) on how to adjust the two pice moonroof. IIRC the front edge needs to be like a mm lower than the roof, and the rear edge fo the front panel like a mm higher than the rear panel. I don't recall exactly, but see if you can find the specs, as adjustment may help.
Old Dec 15, 2021 | 11:29 AM
ctwang's Avatar
ctwang
To chrunck,
Ho, ho, ho....
Last edited by ctwang; Dec 15, 2021 at 11:30 AM. Reason: Incomplete; Needed to address to chrunck
Old Aug 13, 2025 | 06:44 PM
ptkacik's Avatar
ptkacik
It is also odd that D904 showed up for a fault at the TPMS unit. D904 is for the CAS system at the front of the car.
”D904: CAS, K-Can line fault”
Old Aug 16, 2025 | 04:12 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
I think you meant to make this post in a different thread.
D904 indicates a wire fault ANYWHERE in the large multi-master K-CAN (body CAN) network where ~18 different control modules, including CAS, talk to each other. Among its many other functions, CAS also appears to be responsible for detecting K-CAN wire faults (D904). CAS is listed with the D904 fault code for this reason, not because CAS itself is the source of the problem.
Gil-galad
Eastern Iowa MINIs
Oct 28, 2013 07:46 AM
Llanrhaeadr_Cymru
Country Roads MINIs
May 21, 2013 03:58 PM
lil'valentino
MINI5280
53
Feb 28, 2013 07:34 PM
