Interior/Exterior Need help installing Momo Shift knob.
Old Jan 2, 2005 | 11:54 AM
Jeru's Avatar
Jeru
Need help installing Momo Shift ****.
I pulled the stock **** off, and put on the Momo. But it is sitting too high on the stock stem. Do I have to cut it to make it shorter?
Thanks!:smile:
Old Jan 2, 2005 | 12:09 PM
OctaneGuy's Avatar
OctaneGuy
Did you look at this article??
http://outmotoring.com/How_to_MOMOknob.htm
Also check out this THREAD
https://www.northamericanmotoring.co...hifter+install
I found it by typing MOMO SHIFTER INSTALL in the SEARCH box at the upper right corner of your screen.
Old Jan 2, 2005 | 12:18 PM
Jeru's Avatar
Jeru
Yeah, Did all that. I was hoping to have the **** sitting closer to the leather boot. Mine looks like this too
Old Jan 2, 2005 | 12:31 PM
thegooch's Avatar
thegooch
Yes you would have to cut it if you want it lower...which is up to you to do. I didnt cut mine, and I ordered a whalen **** now so I am waiting to see how that goes.
Old Jan 2, 2005 | 12:49 PM
Jeru's Avatar
Jeru
Sounds like its Hack Saw time to get the look I want.
Old Jan 2, 2005 | 12:54 PM
thegooch's Avatar
thegooch
I dont know about. I would use a drummel or sothing of that nature, holding the shaft tight with a smoething spread out to protect you from getting palsitc ash everywhere. The hacksaw will put a lot of strain on the shaft and could bend something.
BamaCooperS's Avatar
BamaCooperS
MOMO Install
I have a MOMO Combat installed in my '04 Chili Red/Black MCS. I was able to drop the **** down to the approximate heigth of the stock ****. First I used a Dremel to reduce the diameter of the stock collar. I then took the MOMO collar and using a drill press and Unibit, I enlarged the MOMO collar to fit down on the stock shaft. I was then able to drop the MOMO **** down on the stock shaft quite far. Now, when I grab the shifter, I'm actually grabbing it lower than I would on the stock ****. Anyway, to each their own, I really like the way the Silver MOMO Combat matches the interior. Happy Motoring in the New Year!
Old Jan 2, 2005 | 12:55 PM
BamaCooperS
MOMO Install
Sorry, but I forgot to add a link to a picture of my MOMO ****:
http://webpages.charter.net/hbrown3124/MOMO.JPG
Old Jan 2, 2005 | 01:12 PM
ripley's Avatar
ripley
I have the exact same ****. What I did was to machine out the inside of the aluminum Momo collar to fit over the ridge on the factory shift rod. Then you can move the **** down to sit squarly on the ridge, tighten it up and then move the clollar up. Fits great, looks great, and best of all, feels great. DO NOT cut the rod!
If you don't have access to a lathe, some personal time with a dremil and grinding attachment will work to.
Old Jan 2, 2005 | 01:30 PM
Jeru's Avatar
Jeru
Problem is, I bought this stubby ****. It's not as tall as the one you guys have.:smile:
Old Jan 2, 2005 | 01:45 PM
Jeru's Avatar
Jeru
Could not wait, so I hack sawed it... Cut through it like butter.
Here is the result!
Old Jan 2, 2005 | 11:35 PM
kenchan's Avatar
kenchan
Here is the result!
Looks good. I was going to say...just pull your boot up all the way
to the little ridge as you have on your hacked picture. I didn't hack
mine.
Old Jan 5, 2005 | 02:37 PM
DevilMini's Avatar
DevilMini
Jeru--- What Momo **** is that? Is it all leather, except for trim ring? All of my older ***** get really hot in the summer!!
Thx,
Devilmini
Old Jan 5, 2005 | 06:47 PM
JCampos's Avatar
JCampos
MOMOs fit great with the Alta shifter I have the "MOMO Automatico" on mine.. looks really nice. Much better to shift with than a ball
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
artguy
R58 :: Coupé Talk (2012+)
Aug 30, 2015 07:56 PM
