Interior/Exterior Quick release steering wheel..?
Old Aug 12, 2019 | 06:16 PM
Kyle Lopes's Avatar
Kyle Lopes
hi my fellow mini owners, I've been doing some research on quick release steering wheels. Before I pull the trigger on the entire assembly, I'm wondering what setups you guys are running? And if you can post pictures of your setup. Thank you
Old Aug 17, 2019 | 08:22 PM
angusp's Avatar
angusp
Overall, this was a no brainier for my street legal but dedicated endurance racing MINI, however I wouldn't really recommend it for a daily driver.
I have an generic NRG quick release with a 330mm Sabelt wheel. I wouldn't recommend anything smaller than 330mm, even then you lose some visibility of the gauges. For a daily I would go with a 350mm wheel.
For the boss, you want a BMW E46 slim boss, like this one:
Amazon Amazon
and for all the bosses I've seen, you need a thick washer on the steering spline to take out about 2mm of slop otherwise.
With a setup like this you will lose the horn, steering wheel controls (if you have any) and the airbag. To avoid throwing a code you will want to remove the battery and put a 13ohm resistor in place of the airbag before you reconnect the battery.
When you remove the airbag clock-spring assembly, you will lose the automatic turn signal cancelling. To fix this I designed and 3D printed a small part which cancels the turn signals (and also acts as the thick spline washer).
Old Nov 2, 2019 | 06:35 PM
minsanity's Avatar
minsanity
OMP, Works Bell, Luisi have a gen1-specific steering hub to which you can install a quick release system. Horn & turn should work. Don't forget the SRS resistors.
Old May 17, 2023 | 02:14 PM
sandextreme's Avatar
sandextreme
Attachment 192783
For the boss, you want a BMW E46 slim boss, like this one: https://www.amazon.com/NRG-SRK-E46H-.../dp/B00HLPMFI2 and for all the bosses I've seen, you need a thick washer on the steering spline to take out about 2mm of slop otherwise.
Attachment 192784
Do you sell this part?
Old Oct 16, 2023 | 03:24 AM
Mortification's Avatar
Mortification
Attachment 192783
Attachment 192784
you sell these lol asking for a friend
Old Feb 26, 2025 | 11:50 AM
H.archer's Avatar
H.archer
.stl
Attachment 192783
Attachment 192784
do you have an stl for this is can use?
jbrier87
17
Mar 22, 2024 08:25 PM
Minicoopr50
Jul 3, 2012 11:23 AM
not-so-rednwhitecooper
Oct 22, 2007 08:19 AM
maxmini
Aug 27, 2005 05:22 PM
