Interior/Exterior Removing Speedo surround
Old May 13, 2019 | 12:02 PM
putttn's Avatar
putttn
How do you remove the speedo surround. Going to repaint the surround.
Old May 15, 2019 | 11:11 PM
Alpha Motoring's Avatar
Alpha Motoring
Speedometer is easy, loosen the two screws on the top and use a plastic pry tool, it’ll pop off. There’s one pressure tab on the bottom, rest is lightly hot glued from factory.
Old May 22, 2019 | 06:36 PM
putttn's Avatar
putttn
No go
The only two screws I see are those on the back panel the speedo is attached to. They are attached to the top of the dash. I unscrewed those and gingerly pried the back panel but I can’t seem to see how that will release. Is it that back panel that is supposed to release and come off with the speedo? I pulled off the dash dimmer and flasher surrounds.
Old May 22, 2019 | 07:11 PM
A383Wing's Avatar
A383Wing
Per the Bentley manual, it's different depending on what year and month your car was made
Bryan
speedysouthpaw
Aug 28, 2014 07:19 PM
Dahlface
May 27, 2012 05:40 PM
Cole9953
Jan 28, 2012 10:12 AM
Brad79
Dec 13, 2011 07:37 AM
moe-jiller
Dec 29, 2010 10:17 PM
