Interior/Exterior R56 Pre-LCI to LCI Interior Swap/Conversion
I was never interested in the NAV unit. I more preferred the large speedo. Although it was good to read about the Mic placement. I'll have to look into that a bit more. I've almost got the aux cable figured out and the only thing not working then would be the Mic for using Bluetooth with my phone...
No I did not. I quit worrying about it. At this point I’ve got an award winning custom stereo and the aux input isn’t even important to me anymore. I’m taking the car to Nationals next year. 👍🏼
Hello to everyone,
I recently bought a MCS R56 (2007 model) and I have a question regarding the pre-LCI to LCI interior swap.
Frankly, I have searched quite a lot online and I have also asked a bunch of Mini specialized technicians, but to no avail, so you are almost my last hope
My car is equipped with manual air condition (not the auto one with the LCD screen) and the controls are pretty worn (they are fully functional but not pleasant to the eye
I have found some better looking pre-LCI panels, but I've also found a few LCI manual a/c panels (including the switches below controlling the windows, fog lights and central lock) from donor cars with the exactly same configuration as mine (no heated seats, front and rear fog lights).
So, my 1 million dollar question is: can I swap directly my old panel with the LCI manual a/c panel? Is it a plug and play conversion (both for the a/c controls and the swithces below) or will it need tweaking and parts exchange (as stated for the auto a/c panels)?? The pre-LCI and the LCI panels look almost identical in the rear but if someone has done or knows about this conversion, I would really appreciate the info!!
Thank you in advance!!!
).I have found some better looking pre-LCI panels, but I've also found a few LCI manual a/c panels (including the switches below controlling the windows, fog lights and central lock) from donor cars with the exactly same configuration as mine (no heated seats, front and rear fog lights).
Hello to everyone,
Well, because I've read about the auto a/c panel conversion and noted the difference between the two panels you mention, I've been also led to believe that the manual a/c conversion will be probably a direct swap, but a confirmation from someone who has actually gone through with it would be nice
Nevertheless, thanks for your answer!
I know this is an ancient thread but thanks for the information. I will be moving forward with the center stack swap on my 2009 to the later "LCI" black controls. I have Automatic AC. I will also be doing a radio upgrade at the same time (most likely going this route: https://www.carnaviplayer.com/mini-c...upgrade-p-1148).
Having ran this setup for a number of years, I would advise against it. Losing the speedo is a disadvantage IF something goes wrong with the radio like it has with me now - I think somewhere behind the scenes, the input flipped away from AUX so I get no sound anymore. I’m thinking of moving to one of the Aliexpress setups where the Android unit is relocated down where the CD player was and the original speedo is retained. The added bonus is I have collected a couple of DuelL and Minimax gauge clusters so.I can use those as well lol.
Interior/Exterior Replacing the Grey Dash Widgets in a Black interior
spaceteam
Jul 24, 2020 08:05 PM
