Interior/Exterior R56S Grill Glue?
Old Jun 7, 2018 | 03:26 PM
Bocadito's Avatar
Bocadito
R56S Grill Glue?
2011 R56 S
Changing the silver grill surrounds to black. Took off the bottom piece and found this.... is it normal to have glue here? It's super-hard and can't be scraped off. Any ideas? Do I need an entirely new grill? Bottom piece won't snap in entirely now.
Old Jun 7, 2018 | 08:05 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Stock, there shouldn’t be any glue there. Trim stays in place by the clips only.
Old Jun 10, 2018 | 08:33 AM
isamin's Avatar
isamin
Bought new (2013) JCW and chrome surround was 1 of first to go. No glue from factory but the clips are weak and crappy.
Flash forward to 2015 and I got a Countryman upper grille bar from ECS and flipped it upside down and mounted it with 3 plastic plugs & pop rivs to the lower portion of the upper grille. Perfect (almost) fit hor & vert so to ensure hi speed safety I used laser glue on the edges.
Car isn't a garage queen and is driven hard & put away wet. No problems in 3 plus years.
ISAMIN
Old Jun 10, 2018 | 02:50 PM
ammodave's Avatar
ammodave
Looks like the previous owner had problems and resorted to JB Weld. I would try carefully grinding off the old glue with a Dremel tool to see if the new surround will lock in properly. You can always use JB Weld to attach the new piece if necessary.
Old Jun 12, 2018 | 08:22 AM
Yep, they did it to hold it on.
bodinski
Detailing 101
Nov 4, 2006 01:14 PM
inkdripz
Detailing 101
Aug 17, 2005 07:59 AM
M7
Mar 22, 2004 11:12 AM
W3IWI
Detailing 101
Sep 9, 2003 09:07 PM
