Interior/Exterior So Where Do You Keep Your JCW Exhaust Bluetooth Remote? I Mounted Mine
Old Apr 27, 2016 | 07:11 PM
  #26
bheights's Avatar
bheights
Not the dash but maybe on the lower instrument panel trim. Seems like there is a lot of room behind it (was thinking about a garage remote setup there as well). It's a $40 part to replace in case it doesn't go well.
Old Apr 27, 2016 | 07:49 PM
  #27
vetsvette's Avatar
vetsvette
Moderator
I'd rather have a hardwire replacement for the BT module. Add a non-locking toggle switch and a relay and do away with all the wireless crap. Until then I'll use the foam for my cupholder that came with the remote.
Old Apr 27, 2016 | 08:20 PM
  #28
bheights's Avatar
bheights
If someone is good at electronics they might be able to figure out how to solder some wires from the bluetooth receiver to make it a hardwire setup. Maybe?
Here is the FCC application with all of the details on the remote and the receiver.
https://apps.fcc.gov/oetcf/eas/repor...id=2ACUNRAT950
Old Aug 12, 2016 | 06:39 PM
  #29
mattkosem's Avatar
mattkosem
In the door.
--Matt
Old Aug 12, 2016 | 06:44 PM
  #30
MiniF55's Avatar
MiniF55
The door! Not a bad idea at all.
Old Jan 28, 2017 | 06:26 AM
  #31
kattanah's Avatar
kattanah
I always wanted it to be built-in
Hi All,
So I have always been thinking how can I have the remote built into the dashboard of my car, keeping an OEM look and feel.
Today, I had the guts to do it, and I decided to grab a hole saw bit along with my drill... and went for the dashboard....
results are remarkable... will leave you with these pics, and would love to hear your opinions
Old Jan 28, 2017 | 07:30 AM
  #32
LormaD's Avatar
LormaD
10-4 Roger That!!!!
Awesome and ballsy!
Have you thought about losing the strap? Would possibly look more custom!
Old Jan 28, 2017 | 07:53 AM
  #33
USA-RET's Avatar
USA-RET
Originally Posted by LormaD
Awesome and ballsy!
Agreed.
No strap would look cleaner, but strap looks fine too since it is add-on JCW performance accessory. Man that is a frickin' awesome solution.
Old Jan 28, 2017 | 08:01 AM
  #34
kattanah's Avatar
kattanah
Originally Posted by USA-RET
Agreed.
Would Love to remove it, but I am keeping it at the moment to make it easier to remove. I am also not sure how it would end up looking with the uneven red plastic ring.
Old Jan 28, 2017 | 12:01 PM
  #35
vetsvette's Avatar
vetsvette
Moderator
If you're serious about removing the strap, it look like you could clip the "D" ring part off and with some judicious use of a fine small file make it look symmetrical. Looks good as is though. What size hole saw did you use? You've got me thinking now.
I still believe the best solution is to have the valve hardwired and controlled by a toggle switch on the dash. The BT system requires wiring from the front to rear of the car anyway, why add the complication of the BT system. Just more opportunities to fail in my opinion. The car has enough complicated systems, why add another unnecessarily. KISS!
Old Jan 28, 2017 | 01:43 PM
  #36
kattanah's Avatar
kattanah
I actually my do that
I used a 29mm hole saw (https://www.amazon.com/gp/product/B0...bhz_bw_c_x_1_w) tip: punch it with your hands first, then use the drill.
Old Jan 29, 2017 | 06:06 AM
  #37
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
In my toolbox because I disabled the BT valve so it stays on track mode all the time. No need to press the button to turn it on anymore because it is always on.
http://vrosetta.blogspot.com/2016/12...uning-kit.html
Old Jan 30, 2017 | 02:16 PM
  #38
mkt3000's Avatar
mkt3000
I did that a few months ago - now the button lives in the glovebox.
Old Feb 1, 2017 | 07:33 AM
  #39
3rdcoastmini's Avatar
3rdcoastmini
Well done. What I want to know now is how that piece comes off you cut the hole in. I have always wondered about replacing with red JCW parts if I could find them.
Old Feb 2, 2017 | 09:09 AM
  #40
kattanah's Avatar
kattanah
The hole saw bit will catch the piece... it won't drop
Old Feb 10, 2017 | 03:14 AM
  #41
kattanah's Avatar
kattanah
So I decided to remove the strap, and keep the D ring for now... looks better
Old Feb 10, 2017 | 03:22 AM
  #42
MiniF55's Avatar
MiniF55
It's more subtle without the strap. Looks great!
Old Feb 10, 2017 | 05:53 AM
  #43
vetsvette's Avatar
vetsvette
Moderator
That does look much better. As of a couple of days ago I keep mine in the secret compartment. I never had a problem with mine until I started to wear my Apple Watch. On my 160 mile round trip to the dealer it shut off multiple times and I said the heck with it and disabled the BT and locked the baffle open.
Old Feb 10, 2017 | 06:39 AM
  #44
MiniF55's Avatar
MiniF55
Vetsvette did you disable by unplugging the BT from the unit in the trunk panel?
Old Feb 10, 2017 | 06:44 AM
  #45
vetsvette's Avatar
vetsvette
Moderator
Yep.
Old Mar 1, 2017 | 08:18 AM
  #46
SnowriderinFl's Avatar
SnowriderinFl
On the Steering Column
I mounted mine in the open space on the steering column right behind the directional lever. Held in place by Velcro (which is white, I ran out of black)
Old Mar 2, 2017 | 08:59 AM
  #47
USA-RET's Avatar
USA-RET
Okay, so not having the "acorns" to take a cutter to my dash, I opted for the above as a nest spot for mine. Tried it on the left side of the steering column and saw that it fits fine, but unless you use a Velcro to hold it in place, using the button pushes the unit deeper into the cavity. It does however stop at a point where you can easily push the button to activate it and using the strap to pull the unit out if you wish.
I then decided to move it to the right side of the column and find that is nests quite nicely there. I can active the button easily and when doing that, the unit doesn't get pushed deeper into that cavity. No Velcro is necessary for this position as the unit seems to be quite secure. I just unlocked the steering wheel adjustment handle, lowered the wheel. put the BL device in the opening and just raised and wheel enough to gently hold the BT unit in place. I don't fiddle with that steering adjustment at all when entering or leaving the car, so it's basically a "set and forget" deal for me.
Being at almost eye level, I can see it blinking occasionally without having to take my eyes off the road. You catch that red flash out of the corner of your eye.
Works great!
Old Apr 19, 2017 | 08:16 AM
  #48
arviddumon's Avatar
arviddumon
​​​​​Do you still have the strap in one piece and are you willing to sell it for a reasonable price?
Old Apr 19, 2017 | 07:29 PM
  #49
shmandrew's Avatar
shmandrew
Thanks for that link It's so much nicer not messing with the remote every time I start the car and love that I don't have to worry about the valve randomly closing anymore. Now if I could find a way to have sport mode on by default, I'd shave another second off my startup routine
Old Apr 19, 2017 | 11:55 PM
  #50
arviddumon's Avatar
arviddumon
you wouldn't still have the strap in one piece and are willing to sell just the strap?
