Interior/Exterior DRL With Switchback LED?
Old Jan 14, 2016 | 06:38 AM
Smitha6's Avatar
Smitha6
2003 R50:
I recently had to replace the DRL in my Mini and noticed for the first time there are 2 bulbs (I've had this car a month, cut me a break), the white DRL and the blinker.
Well I got to thinking, is there a housing with just 1 light that I could use a Switchback LED in instead? (White all the time then blinks amber when I use my blinkers)
AND/OR would it be better to just put a switchback in the blinker's place and have 2 bulbs in there still? Would the switchback still light up white when not in blinker mode, or is there no power to it when the blinker is not engaged?
I feel like the single switchback bulb would be a cleaner look.
Old Jan 14, 2016 | 06:41 AM
TWISTER's Avatar
TWISTER
Your DRL is your high beam running at 50% power
Old Jan 14, 2016 | 06:49 AM
Smitha6's Avatar
Smitha6
I must not be calling it the right thing then, but I hoped my description was enough.
I'm talking about the light below the headlights and above where the fog lights go. Where the turn signal is.
Old Jan 14, 2016 | 06:50 AM
TWISTER's Avatar
TWISTER
Ahh the parking light and turn signal light
Old Jan 14, 2016 | 06:53 AM
Smitha6's Avatar
Smitha6
AHHH!!! Yes, that one. Like I said, I'm new!
Old Jan 14, 2016 | 06:57 AM
TWISTER's Avatar
TWISTER
It's all good - we were all new at one time.
Using a switchback will throw an error code and you'll have to rewire. It will also leave a hole for moisture and you don't want that. Just get a bulb that has a silver coating and blinks amber
Old Jan 14, 2016 | 07:01 AM
Smitha6's Avatar
Smitha6
Wouldn't a load resistor be the fix for that? I mean, there is still a bulb there, it just takes less power.
That's why I was trying to see if there was a housing with just one hole or that accepts just one bulb.
Old Jan 14, 2016 | 07:18 AM
TWISTER's Avatar
TWISTER
load resistor poss will work - no other housings I know of
jeph swift
Nov 20, 2023 10:00 AM
scottbushey
Feb 7, 2017 09:55 PM
joarda
Dec 21, 2015 07:18 PM
Dec 11, 2015 02:08 PM
Rune
Electrical
Dec 3, 2015 11:11 AM
