Interior/Exterior Help! Cravenspeed Ngauge Problem
Old Jan 30, 2015 | 09:20 PM
GEMSTER's Avatar
GEMSTER
Just finished installing the Ngauge, and one of the gauges is not working. (I have the boost and water temp gauge) But its not that simple. When I start up the car, both gauges will light up and do a dial sweep. But after that, the water temp gauge will not work. I thought it was a faulty connection on one of the daisy chain connectors, so i tried to plug into another connector (all combinations were tried), but still no dice. Then i swapped the master cable from the boost gauge to the water temp. Now the water temp works but not the boost. So now what?
Here is a video of the problem:
Has anyone had this problem?
Im asking here first because Cravenspeed is not open till Monday.
Old Feb 2, 2015 | 10:54 AM
CravenSpeed's Avatar
CravenSpeed
Vendor
Sorry we kept you waiting. Since both gauges work when plugged directly in, that suggests that they were both built as the master gauge by accident. We'll get an exchange out to you as soon as possible.
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
cb_smalls
Aug 31, 2015 06:13 AM
jziran
Aug 24, 2015 04:50 PM
lotuseyes
Aug 18, 2015 12:07 PM
