Interior/Exterior Fender reflector removal...
Old Dec 14, 2014 | 12:37 AM
Centium's Avatar
Centium
I have tried searching the forum for the answer, but I can't seem to find it anywhere... How do I get the fender reflectors off of a 2011 MCS? I want to remove them to do a proper tint. Thanks in advance.
Attached Thumbnails Fender reflector removal...-img_1634.jpg   Fender reflector removal...-img_1633.jpg
Old Dec 14, 2014 | 05:03 AM
spiney's Avatar
spiney
I've only done the fronts as part of a bumper removal, but as as far as I remember:
Pull back the wheel well liner. You may need to remove some of the fasteners, there are about 5 attaching it to the back of the front bumper, and/or the big plastic circles that let you access the light bulbs, to let you get enough access.
Remove the light wiring (simple twist and pull).
Undo the pressed metal "nuts" at the top and bottom of the reflector. I've never done the rears, but it's most likely similar.
Old Dec 17, 2014 | 07:31 PM
spingq's Avatar
spingq
if you're going to remove the arches, you might consider simply replacing them with the Euro arches which have no reflectors at all. it'll cost a bit more obviously but will give you a much better result for the look you're going for.
Old Dec 18, 2014 | 08:31 PM
ra2fanatic's Avatar
ra2fanatic
held in place by a 10mm unit (or 8mm, one or the other). Just move the wheel liner out of the way and find the nut and you'll be good to go.
Old Dec 19, 2014 | 07:11 AM
Centium's Avatar
Centium
Thank you! Good things do come to those who wait...
I took a look earlier today and saw what you were talking about. Should be a pretty simple task.
Old Dec 19, 2014 | 08:17 AM
ra2fanatic's Avatar
ra2fanatic
Peking Duck
Jan 19, 2021 03:17 AM
OutMotoring
Mar 3, 2017 06:29 AM
ccfirelt
Oct 18, 2015 01:02 PM
drum6g
Sep 29, 2015 01:15 PM
BlueCooperS
Sep 25, 2015 10:06 AM
