Interior/Exterior Shift Boot
Old May 6, 2004 | 11:57 AM
bolar's Avatar
bolar
I've noticed the people who put an aftermarket shift boot have to boot extended up to the bottom of the shift ****. My stock boot stops around an inch down from the shift ****. Is this done for appearance? Just wondering.
Old May 6, 2004 | 12:04 PM
chrisneal's Avatar
chrisneal
Perhaps the difference is with people who have short shift kits installed, which often lower the height of the shift **** by 1" or so. Also, there are numerous companies offering aftermarket shift boots of different sizes. I looked around for a while for a red shift boot for my car, but didn't see anything I liked for what I thought was a reasonable price.
Old May 6, 2004 | 12:30 PM
Storer's Avatar
Storer
Yup... I got the Moss shift boot after I installed the B&M. Looks fantastic.
Chrisnl, did you check out the new sponsor's web site? I think that the shift boot is $35, which ain't bad.
Now, as soon as they get Louis Vuitton pleather...!
_________________
~She was actin' cooth until she started spitting out the sunroof through her missin' tooth~
Old May 6, 2004 | 12:54 PM
norm03s's Avatar
norm03s
The B&M shifter is SS and finnished very nice. You can attach the shift boot under the **** or roll it down and expose the shifters shaft, it's up to the owner of course.
Old May 7, 2004 | 11:00 AM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
The factory leather boot is zip-tied to the shaft on the inner side. The ring around the shaft determines the lowest point for the top portion of the boot. As effected by gravity, the upper portion of the boot will always sit on top of the ring and expose part of the upper shaft. To avoid this is by placing something at the desire height to prevent the top of the boot from sliding downward. Usually, several layers of tape will do the trick. :smile:
_________________
Old May 8, 2004 | 12:15 PM
bolar's Avatar
bolar
I was just trying to figure out if there was a specific reason for having the boot at the bottom of the ****. I don't particularly like the look of the boot all the way to the bottom of the shift ****, although Davecsumini yours looks nice, maybe it's because you have the sag at the bottom. Most I've seen are tight from top to bottom.
PsychoRallye
21
Feb 17, 2019 06:08 AM
OutMotoring
Mar 3, 2017 06:29 AM
vetsvette
Oct 22, 2015 09:46 PM
MINI Stupor
Oct 1, 2015 11:36 AM
mini_mike237
Sep 25, 2015 12:45 PM
