Interior/Exterior Post your driving light kits
Old Feb 27, 2014 | 09:36 AM
  #51
CaptainK04's Avatar
CaptainK04
I love the skull and cross bones grill badge! If you don't mind me asking, where did you purchase that from?
Old May 5, 2014 | 07:33 AM
  #52
Saltysalt's Avatar
Saltysalt
Finnally got my lights on this weekend! not my original plan, and i couldnt hide these badboys behind the grill they are too big haha.
im super pleased on the way they turned out, granted it took 10 hours to complete, but i wanted it done the right way. i also had to run to the homedepot and get a few supplies. Took about 5 hours to mount, wire and test basics, understand what was going on and run to the depot. the next 5 hours was finalizing the setup and figuring out what went wrong, come to find out both the inline fuses that came with the kit that sent power to the switches were bad, but we have checked all the other wires, the switches, lights, and the relays..... this was the most frustrating part! glad its done tho, and all the wiring is clean, mounted the switches right next to the sunroof switch. 2 switches: outers and inners
mounting kit: none, just drilled holes right into the plastic front lip
Attached Thumbnails Post your driving light kits-10155926_10101092613495701_267276845008289548_n.jpg   Post your driving light kits-10173676_10101092613440811_6913601857493355158_n.jpg   Post your driving light kits-10348309_10101092613530631_7897220605586228591_n.jpg
Old May 5, 2014 | 09:14 AM
  #53
danjreed's Avatar
danjreed
In the process of wiring mine up. Anyone know a good wire to tie into on the r55/56 LCI cars with Xenons for the high beam?
Looking at wire diagrams it's hard to make sense of what's going on out at the headlight in terms of high/low beam versus leveling motors..
I'd rather tie I to the footwell module in the driver's kick panel.. (Pin 4? 41?)
Old May 5, 2014 | 09:29 AM
  #54
Saltysalt's Avatar
Saltysalt
I bypassed my headlights, i wanted mine on when i wanted them on =)
Old May 5, 2014 | 09:51 AM
  #55
MotorWorf's Avatar
MotorWorf
And, they look good!
Old May 6, 2014 | 03:37 AM
  #56
N2MINI's Avatar
N2MINI
Here my 2nd rendition of behind the grille driving lights. Need to try to raise them a touch but they won't come up as far as they really need too due to the bumper brace is right there and what these are bolted too. Went with green tint to be different but have other colors to maybe swap out down the road..
Old May 6, 2014 | 06:08 AM
  #57
scubbysnacks's Avatar
scubbysnacks
Got mine off eBay shipped from the UK $160AUS + $5 for ebay LEDs ran them off the park lights use them as LED day time running lights, park lights + driving lights. At night they light up with xenon's, sorry no pictures but for $160 I'm happy.
Kit came with a template to cut the front grill along with lights, brackets wire as well as a relay and switch which I didn't use.
Old May 6, 2014 | 06:18 AM
  #58
Saltysalt's Avatar
Saltysalt
i really enjoy the hidden lights, what actual lights are those n2?
Old May 6, 2014 | 07:06 AM
  #59
N2MINI's Avatar
N2MINI
They are a no name ebay deal. 4.5'' LED
Old May 6, 2014 | 08:50 AM
  #60
soccerbummer1104's Avatar
soccerbummer1104
cross post of an older post in my build thread over in the drivetrain section:
I HAD an alta bar, but with my putting in a large-ish A2W heat exchanger and KEEPING my A/C, I no longer had room for the alta bar and the way it mounted, so to the drawing board I went and here are the results!
in summary
bent 1/2" square stock to bumper profile. This will mount to underside of bumper using rivnut inserts into the bumper, and M6 bolts.
Using 1"x.5"x.125" channel for the "drops" as they are rigid in both directions.
here is one side "jigged" up before welding
welded (this is when I was quite new to aluminum)
Rough shape of the inside portion of the mounting bracket
turned some mounting points on the lathe out of 6061
welded them on from the back side
And then to mount it to the bumper I used rivnut inserts to put them into the bottom of the bumper (not the back and using bolts like is common.
Rivnuts are simply threaded inserts that are installed much like a rivet. Drill a hole through thin (ish) metal, put one in, squeese, the back side expands, and then viola! you have a threaded mounting point through a thin walled base material!
before use:
close up of install :
bumper
I then drilled holes for clearance and counter sink into the bracket I made, and bolted her onto the bumper!
Lines up nicely!
installed with the w2A exchanger mocked up.
sticking through the grill
And with the exterior mounting bar bolted on
Hope you all enjoyed! I have lights now mounted to the outside bar, but the car is currently apart for the build, so no newer pictures than these.
hope you enjoyed!
the lights are 6" PIAA lamps though with a 55watt HID kit dropped in.
Not to ever be used on the street if any traffic is around, but they make for a nice 180° (almost) of light coverage on those mountain twisties at night!
Old May 6, 2014 | 04:06 PM
  #61
Oxycooper's Avatar
Oxycooper
Finally got my lights installed
Wohnson89
Jun 10, 2020 04:53 AM
Dec 23, 2015 10:36 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
