Interior/Exterior Post your driving light kits
Old Jan 25, 2013 | 10:19 AM
  #26
mini stig's Avatar
mini stig
Put mine on last night. They are 5 inch KC Apollos with factory brackets all of which I got from outmotoring.
Old Jan 25, 2013 | 12:03 PM
  #27
jonnieoh's Avatar
jonnieoh
Their legality varies from state to state.
In New York state, it is legal to use them, as long as they're used with ONLY the high beams activated, (obviously).
Originally Posted by leaf_fan_1988
Where do you guys use those lights? Or are they just there cus thy look awesome?
I know they'd come in handy on back country roads, but are they street legal?
I saw one mini with a roof rack, and the hella lights mounted in front of the rack, doubt that's street legal, but it looked reallly good.
Old Jan 25, 2013 | 12:04 PM
  #28
Naylia's Avatar
Naylia
CA is 6 lights total - driving lights have to switch on with the high beams.
Old Jan 26, 2013 | 04:16 PM
  #29
WLSH BST's Avatar
WLSH BST
Piaa520 smr
PIAA520 SMR + madness brackets
Old Jan 27, 2013 | 11:56 AM
  #30
SouperBuddha's Avatar
SouperBuddha
Thanks for all the pics everyone, I think i may go for 2 Hella 500 lights on the upper grill, like the picture above.
Old Jan 27, 2013 | 02:02 PM
  #31
MotorWorf's Avatar
MotorWorf
I really want to see what 5" lamps look like, could post a photo?
Oh, and as far as legal. That varies from state to state. And, Primarily in response to trucks carrying multiple driving lights on the roof. Some require them to be on with the high beams, some limit the number and there may be other restrictions
Old Jan 27, 2013 | 03:04 PM
  #32
mini stig's Avatar
mini stig
Here ya go MotorWorf.
I have mine hooked in with the high beams and the really make driving at night a whole lot better.
Old Jan 27, 2013 | 05:45 PM
  #33
minime331's Avatar
minime331
i would go with the 500 FF series better light pattern then the normal 500
Old Jan 29, 2013 | 09:44 AM
  #34
N2MINI's Avatar
N2MINI
I hid mine alittle. Plus makes it easier to wash!!..
Old Jan 31, 2013 | 08:02 AM
  #35
KMalinich's Avatar
KMalinich
Old Jan 31, 2013 | 11:26 AM
  #36
Meboko's Avatar
Meboko
I like that.......a LOT.
Old Jan 31, 2013 | 11:49 AM
  #37
IndiCooper's Avatar
IndiCooper
I put these on STKRS this past October and love them!!
4 hella 500 Black Magic <3
0A517CCD-1624-4E01-87D1-27649270BE12-333-000000435C9B0C16.jpg?t=1358802792
Old Jan 31, 2013 | 12:33 PM
  #38
MellowYell's Avatar
MellowYell
What brackets did you use to mount them? They look sweet!
Old Jan 31, 2013 | 02:44 PM
  #39
IndiCooper's Avatar
IndiCooper
lights from tire rack and bracket from VIP, www.vipcustomparts.com
Old Jan 31, 2013 | 02:49 PM
  #40
minime331's Avatar
minime331
hey Celia this is an gen 1 section only haha jk.
now you got stkrs with lights you need to get the ugly duckling with some lights
Old Jan 31, 2013 | 03:13 PM
  #41
IndiCooper's Avatar
IndiCooper
SO VIP makes brackets for 1st Gens too geez Chris, but yes the Duck will have light someday...
Old Feb 11, 2014 | 04:04 PM
  #42
Oxycooper's Avatar
Oxycooper
Originally Posted by Drakosd
HELLA 500 , Brackets from Outmotoring.com . I had to modify the brackets a little but they are SUPER BRIGHT and I don't have to have the highbeams on to use them like the manufacturer lights.
How did you modify the brackets to fit. I'm having trouble fitting the bumper once the brackets are mounted.
Old Feb 14, 2014 | 08:04 AM
  #43
Drakosd's Avatar
Drakosd
I had to make some small cuts to the bumper itself ( hidden underneath so it can't be seen) and I drilled holes into the metal bumper guard of the car behind the bumper and mounted there. I didn't like the way they had it set up. I would of just welded if I had the equipment at home. I would take some photos for you to better explain but Ive since sold this MINI. sorry.
Old Feb 14, 2014 | 02:11 PM
  #44
Saltysalt's Avatar
Saltysalt
Originally Posted by DixonL2
An older pic, but I still like mine.
Hella 500 fogs outer, Hella 500 driving lamps inner.
6 3/8" diameter
this is what im in the process of doing, its been so darn cold in the winter i havent been able to pull my bumper off to put this in, unfortunatly i wanted to run hella 500ff driving and fog, but i onyl have 4 500ff drivings. but mine will be in that same spot, im going to make my own light bar tho, i just need to mount them up, i have the bar itself actually made.
how is the VIP bar? just incase if i get frustrated and give up on my own creation
Old Feb 18, 2014 | 06:57 AM
  #45
DixonL2's Avatar
DixonL2
Mine's not the VIP bar, it was an older eBay purchase. Very stable, and in just the right position. Turns out they're incredibly easy to make using steel angle, tubing, and long bolts. If only I could WELD, I'd make a few and sell 'em!
Old Feb 18, 2014 | 07:42 AM
  #46
Saltysalt's Avatar
Saltysalt
yea, thats why i decided to make my own, the VIP is way too much for what it is
Old Feb 19, 2014 | 06:29 AM
  #47
DixonL2's Avatar
DixonL2
For those putting these on, I noted this before but it's worth noting again: Use a trailer wire plug to connect the lights to the car. This way, you can unbolt the driving light "crossbar" and remove the lights if necessary, say, to bring the car to service level 1 (where you remove the front bumper cover, bumper, etc.). It's MUCH easier to wire in a plug than it is to cut/splice wires later. The trailer plug has a ground and (3) other wires, actually allowing you to wire the lights completely separately from each other, or to run driving lights, fog lights, and perhaps another accessory (a siren?) by using the common ground. DEFINITELY run a grounding wire, don't just ground to the bumper - this allows for off-vehicle circuit testing.
Old Feb 19, 2014 | 07:20 AM
  #48
Saltysalt's Avatar
Saltysalt
that is a great idea
Old Feb 19, 2014 | 02:50 PM
  #49
jibber11's Avatar
jibber11
Ditto
Old Feb 19, 2014 | 02:52 PM
  #50
jibber11's Avatar
jibber11
The details on this set up?
