Interior/Exterior Removing lower grill
Old Dec 11, 2012 | 06:45 PM
Ermin's Avatar
Ermin
How do I remove the lower center grill? The black plastic one between the fog lights.... Do I have to remove the bumper? I can see tabs holding the grill onto the bumper looking down from top. But are there more screw to remove before the grill can come off?
Old Dec 12, 2012 | 12:05 PM
Ermin's Avatar
Ermin
Bump
Old Dec 12, 2012 | 03:22 PM
fenderless 33's Avatar
fenderless 33
Well I have bee trying to get the same type of info. I want to get the lower black air dam below off for paint and noone seems to be of help. From what I have read you will have to take the front bumper off but don't shoot if I am wrong, I can't get info either and the stealership isn't any help. The reply was bring it in and we'll take it off for you [at $100.00 an hr]. I don't want them to take it off or I would not have called. Mini's support for DIY people is the worst. American cars are much better. I will never buy a MINI again just for this reason. I want to work on my own cars and know them so when something goes wrong away from home at least I can get home.
w
Old Dec 12, 2012 | 03:30 PM
automan21's Avatar
automan21
Yeah safest way is to remove the bumper. Its not that hard just a few pop rivets and bolts/screws. I did it to install a FMIC.
Old Dec 13, 2012 | 04:25 AM
Ermin's Avatar
Ermin
automan21,
Do you have any link you can point me to on steps in removing the bumper?
Old Dec 13, 2012 | 05:35 AM
MikewithaMini's Avatar
MikewithaMini
Originally Posted by Ermin
automan21,
Helix13.com has a video for removing the bumper for the installation of the intercooler. It is the best I've found so far.
Old Dec 13, 2012 | 06:14 AM
automan21's Avatar
automan21
Yes^^^^
Old Dec 13, 2012 | 04:52 PM
Ermin's Avatar
Ermin
Mikewithamini
Thanks! That's also the same video I've found couple of days ago too..... I will look at it again!
Automan21
Your , "Yes^^^^" means you have additional steps? Or you are yes-sing on Mikiwithamini's link? ;p
Old Dec 13, 2012 | 05:07 PM
Scooter09's Avatar
Scooter09
This may not sound like a solution for you, but I've removed mine without taking the bumper off (this was on an S model). If you bang it hard enough with your fist around the edges it will pop loose, then you just have to maneuver it out. It's impossible to put it back in that way though.
Old Dec 13, 2012 | 05:25 PM
automan21's Avatar
automan21
I was yes-ing on Mikiwithamini's link
Old Dec 14, 2012 | 07:21 AM
tecnica's Avatar
tecnica
I just did this last week
You can remove the grill without removing the bumper, but you are taking a chance on breaking a tab. There is no way to put it back on without removing the bumper though.
I used the instructions from Alta's intercooler install.
http://www.altaperformance.com/share.../ampeng420.pdf
Hope this helps
Old Dec 20, 2012 | 05:55 AM
Ermin's Avatar
Ermin
I figured out how to take off the bumper cover....pretty easy. Looking at the way the lower grill snaps on the bumper...I doubt I would be able to bang it out without removing the bumper. Luckily I didn't go that route or there will be more stuff to fix later.
Aug 19, 2015 12:51 PM
Getrieben
Aug 15, 2015 09:09 PM
minipopkart
Aug 13, 2015 05:22 AM
