Interior/Exterior Alta boost gauge kit
Old Oct 16, 2012 | 08:00 AM
blakeslee_a's Avatar
blakeslee_a
What is everyone's opinion about the alta boost gauge kit? I've heard both good and bad about the prosport gauges but I like this kit because it is the closest match to OEM I have found. Anyone who has experience with the kit/ prosport gauges feel free to leave your input
Old Oct 16, 2012 | 08:19 AM
DneprDave's Avatar
DneprDave
Marshall instruments has gages that were made to match MINI gages.
http://www.marshallinstruments.com/c...per_gauges.cfm
Cravenspeed sells them too.
http://www.cravenspeed.com/gauges-gauge-mounts/
Dave
Old Oct 16, 2012 | 08:34 AM
submitaweasel's Avatar
submitaweasel
Prosport gauges are cheap and the alta version is overpriced. Its that simple. The only problem I have with mine is soon after installing I hit a pothole and it was enough to jolt it slightly out of whack. It now reads ~1.5 low. When the car is off it reads -1.5 vac. I dont really even have a need for a boost gauge though, and it only cost me $40 so it doesn't bother me much. It still will read 15psi in cooler temps
Old Oct 16, 2012 | 08:42 AM
blakeslee_a
Dave, i found those gauges but on the main page they are chrome trim. I have a '10 MCS and the trim around the tach and speedo is light grey, and not chrome. however i just read it again and they come stock as grey and come with a snap on peice that is chrome. This is starting to look like a better option so thank you for your comment
submitaweasel, how do you have the gauge mounted and where/how did you tap to get a boost reading without the boost port adapter?
Old Oct 16, 2012 | 09:12 AM
Bigprfed22's Avatar
Bigprfed22
Pro sports in my experience have not been accurate and they are off by 4+lbs with the electrical ones ive been through. Defi and Stri for me.
Old Oct 16, 2012 | 09:31 AM
DneprDave's Avatar
DneprDave
Here's another thread that may interest you.
https://www.northamericanmotoring.co...e-install.html
Dave
Old Oct 16, 2012 | 02:27 PM
Mini///M's Avatar
Mini///M
I haven't really gotten a chance to use it but from what I've played with it I'm happy with the ALTA kit. Pretty simple install. I will only say that I wish I had a different dial face to match more closely to the MINI gauges or a complete digital display.
Old Oct 16, 2012 | 02:32 PM
submitaweasel
Whoops, did I wander into the wrong forum again? I've got an R53 all you need to do on those is get a T fitting and some vacuum like.
silence2-38554
98
Sep 21, 2016 02:52 PM
AWOL
Mar 28, 2016 10:51 AM
wkp1219
Nov 13, 2015 07:52 AM
stierzy34
Sep 15, 2015 04:40 PM
