Interior/Exterior R56 front bumper removal/replacement
Old Mar 20, 2012 | 05:37 PM
red318is's Avatar
red318is
Does anyone have a guide to replacing a front bumper on a non-S R56?
Old Mar 20, 2012 | 05:53 PM
teamrubixcube's Avatar
teamrubixcube
http://www.altaperformance.com/share.../ampeng420.pdf
A non-S and S should be the same as far as the bumper goes I believe. I just removed mine a week or so ago using that guide. Once you get going you find little tricks and don't need to remove as many of the two-piece fasteners.
Here's a video as well: http://www.youtube.com/watch?v=Hpg4YodLiIw
Good luck!
Old Jul 6, 2012 | 02:36 PM
Mindspin311's Avatar
Mindspin311
Posting in this so I can find it later. Trying to remove my fog lights to apply some yellow tint.
Old Jul 7, 2012 | 11:18 AM
ammodave's Avatar
ammodave
FWIW you can remove and replace the fog lights without removing the bumper. I replaced my parking lights with oem fogs about a year ago by working thru the wheel well. Basically, you first remove the headlights so you can reach down inside the cavity and remove the fog lights from the bumper (an offset torx screwdriver and a mirror will be handy). Then (while still working in the cavity) you remove the lights/reflectors from their mounting bracket. The right light can then be removed from the car thru the lower bulb access hole in the right fender well. The left side is more difficult because the washer bottle is in the way. You'll have to partially remove the left fender liner, remove the mtg bolts on the bottom of the bottle and the plastic fastener at the top. Now you can slightly lift the bottle and pull it rearward. It's a tight fit but the left light can then be removed thru the fender well. It took about 15 min to remove the right and about 45 min to do the left.
FLYM1N1
Aug 15, 2015 11:20 AM
smlzilla
Aug 14, 2015 07:00 PM
JHolland
Aug 13, 2015 10:47 PM
skippermini
Aug 12, 2015 10:05 PM
