Interior/Exterior Driving Lights Grille
Old Jul 9, 2012 | 07:09 AM
Vapok's Avatar
Vapok
Hey Folks,
Probably asked once already, but I can't find it.
So, I have the dealer installed driving lights on my 2012 R55. I also have the honeycomb grille.
I have a few grille badges that I want to put on to the grille, and the instructions say to remove the grille. Easy enough, pop off the 4 snaps on the top.. and whoa.... Driving Lights.
So, I can't get the grille off. The driving lights go through it. After some inspection, I realize that getting the driving lights off is actually going to be a production. It's 6 screws and then I have to clip the zip tie off of the wire connector and unplug it.
Here are my questions:
1) Am I doing this the right way?
2) Is there a better way?
3) Does snipping the ziptie that holds the connector in place void any warranties?
As an aside, I was able to get the grille badge on, but not without smashing my knuckles inbetween radiator and grill, and was only able to finger tighten the bolts.
Old Jul 9, 2012 | 10:47 AM
Mini///M's Avatar
Mini///M
I don't have this experience but if you unplug the lights and cut the ziptie to get to the grill I don't see it being a problem. Its pretty easy DIY. If you want to be sure to avoid any BS problems with your dealer just make sure you a similar ziptie and call it a day.
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
