Interior/Exterior Need Major HELP! Stripped window regulator bolt
Old Aug 18, 2011 | 05:00 PM
bmwboyee's Avatar
bmwboyee
So I was trying to replace my window regulator and while trying to remove the "sprocket" that holds the window I think I stripped the hex bolt. It is extremely tight in there and it would not budge. I put PB Blaster on it and let it soak and everything. Guess the pressure was too much and it wouldn't break loose so it stripped the bolt.
So the question is, is there any way for me to remove the window while still connected to the regulator? I have the window rolled all the way down. I'm not sure if i can get to the two bolts at top to remove the regulator.
Is there a way for me to turn the "sprocket" to get it loosened?
Any help is greatly appreciated. I work in Mexico and it is extremely dusty and I would rather not go to work with my window rolled down the whole day.
Thanks in advance.
Old Aug 18, 2011 | 05:18 PM
JAB 67's Avatar
JAB 67
Do you have the 'special' tool that makes removal of that 'sprocket' so much easier? It cost me $75.
Old Aug 18, 2011 | 06:10 PM
bmwboyee's Avatar
bmwboyee
I don't :(. The DIY i read said I could use a 5MM or 3/16 hex :(
Old Aug 21, 2011 | 11:52 AM
bmwboyee's Avatar
bmwboyee
ended up taking it to a local shop that did a great job. $130 in labor and I supplied the part. They did an excellent job.
Old Aug 21, 2011 | 01:28 PM
less2's Avatar
less2
Glad it worked out!!!! Phew!!
Old Aug 22, 2011 | 08:25 PM
bmwboyee's Avatar
bmwboyee
now this stupid thing won't roll up. I hear the motor trying to work but it isn't going up. Looks like it is back to the shop and have to take 1/2 day off of work. Not happy.
UncDeo
Nov 4, 2019 04:08 AM
BucksCountyR57
R57 :: Cabrio Talk (2009+)
Sep 21, 2015 05:42 AM
mimaal
Sep 4, 2015 09:09 AM
zr0z
Sep 3, 2015 04:50 PM
hardy616
Sep 2, 2015 08:32 AM
