Interior/Exterior Ultragauge Install
Old Feb 8, 2013 | 06:26 PM
  #76
Gambedegallina's Avatar
Gambedegallina
Successful UltraGuage Install
Installed UltraGauge (v. 1.2) in my 2013 MCS. As jbat66 says, it is pretty much plug-n-play. The new version correctly configured the detect on/off functions which was the problem with battery drain in earlier versions. Configuring pages and gauges is easier than the massive, detailed directions make it seem. Pretty intuitive.
I mounted below dash just to left of center console. Following a suggestion to adapt color by using photographic flash gel (thanks jbat66) I got a dark orange (it almost looks red) acetate "report cover" from a local stationery store and cut out and placed piece over UltraGuage screen. Cut it about 2mm wider and longer that screen size and it will tuck perfectly into bezel.
Size about (39mm x 71 mm)
And it looks sweet.
Made an "L" bracket from 2 plastic angle iron end caps from hardware store, $0.39 each. Covered both with velcro loop material and used hook sections on back of guage and on lower dash cover. Full access to menu and up/down buttons. I taped the two brackets together for better stability. Couldn't find a plastic L in larger dimension and didn't want to use aluminum.
Old Feb 9, 2013 | 07:46 AM
  #77
jbat66's Avatar
jbat66
That turned out great.
I haven't done my own suggestion yet. lol
I'm glad to see how great it looks.
Old Feb 10, 2013 | 08:46 PM
  #78
Hujan's Avatar
Hujan
And it looks sweet.
Very nicely done! Looks great! What brand cover did you buy?
Also, do you have any shots of the "L" bracket you made? I'm having trouble picturing what you did. Any reason you didn't just stick it on with the velcro included with the gauge?
Again, bravo on the job.
Old Feb 10, 2013 | 10:29 PM
  #79
Gambedegallina
Ultragauge install
Attached is bad picture of rear of install. Used L bracket to position gauge to be visible in location pretty low on under-dash cover.
Here's a link to angle iron end cover like ones I used. Should be available at any decent hardware store:
http://www.marshallshardware.com/pro...?uid=2-141-668
Hope this helps.
The "report cover" is just a generic student report cover that happened to be just right color wise.
Something like this, only with coler, of course (and I actually paid $0.49).
http://www.officemax.com/office-supp...ct-prod2870118
Old Feb 11, 2013 | 07:15 PM
  #80
Hujan's Avatar
Hujan
Hope this helps.
Thanks for the pic and the explanation. I see what you did now. That's a very clever idea. Nicely done!
I'll try and pickup a report cover tomorrow and see what I find. I have an Office Depot right down the street. Thanks again for the help!
Old Feb 12, 2013 | 11:18 AM
  #81
Turboed's Avatar
Turboed
Has someone mounted their UG above the CD-Player Slot (so you could still use CDs)?
Old Feb 12, 2013 | 01:29 PM
  #82
uconnhuskiesfans's Avatar
uconnhuskiesfans
perfect spot is to the left of the steering wheel and to the right of the left most air vent, it fits great there
Old Feb 12, 2013 | 01:45 PM
  #83
Turboed's Avatar
Turboed
Unfortunately, I already got a gauge there. So I need a good place, but not close to the Rev Counter. :-/
Old Jun 27, 2013 | 02:01 PM
  #84
nrfitchett4's Avatar
nrfitchett4
has anyone been successful in using this as a scanner. Seems most reports are that it has trouble reading and clearing codes.
Old Jun 27, 2013 | 08:00 PM
  #85
wzabrouski's Avatar
wzabrouski
Won't read or clear codes on my R60. I am guessing this is the case for all the N18's but I could be wrong.
Old Jun 28, 2013 | 01:45 AM
  #86
nrfitchett4
Decided to try the bt adapter and android app for now.
Old Aug 13, 2013 | 08:11 PM
  #87
wzabrouski's Avatar
wzabrouski
Has anyone with the updated version had to change the settings in order to stop the power draw? I have been dealing with a dead battery if I don't drive my car for more than two days. Dealer says everything is working properly and something is triggering the FRM module when the car is off? Ultragauge?
Old Aug 13, 2013 | 08:56 PM
  #88
Mical's Avatar
Mical
No problems here.. mine sits for a week at a time - no issues.
You might want to have your battery load tested at local parts store, most do it for free.
Old Aug 13, 2013 | 09:39 PM
  #89
Gambedegallina
No issues. Car has been parked for up to 5 days with Ultraguage installed. No issues.
Old Aug 14, 2013 | 06:49 PM
  #90
uconnhuskiesfans
No issues here with the updated ug. Why not unplug yours and see if the battery continues to drain in a few days to rule it out?
Old Oct 20, 2014 | 06:03 PM
  #91
Kimbo80's Avatar
Kimbo80
Installed UltraGauge (v. 1.2) in my 2013 MCS. As jbat66 says, it is pretty much plug-n-play. The new version correctly configured the detect on/off functions which was the problem with battery drain in earlier versions. Configuring pages and gauges is easier than the massive, detailed directions make it seem. Pretty intuitive. I mounted below dash just to left of center console. Following a suggestion to adapt color by using photographic flash gel (thanks jbat66) I got a dark orange (it almost looks red) acetate "report cover" from a local stationery store and cut out and placed piece over UltraGuage screen. Cut it about 2mm wider and longer that screen size and it will tuck perfectly into bezel. Size about (39mm x 71 mm) And it looks sweet. Made an "L" bracket from 2 plastic angle iron end caps from hardware store, $0.39 each. Covered both with velcro loop material and used hook sections on back of guage and on lower dash cover. Full access to menu and up/down buttons. I taped the two brackets together for better stability. Couldn't find a plastic L in larger dimension and didn't want to use aluminum.
That looks absolutely amazing! What did you guys do with the the actual cable, so it's not in the way? -Noob that just received the gauge on Saturday
Old Oct 21, 2014 | 01:32 PM
  #92
Gambedegallina
It is very easy to drop the cover panel below the dash which extends from the bottom of the dash towards the pedals and covers the steering column. As I recall there are three Torx screws along the bottom of the dashboard. Sitting in the driver's seat for reference, I ran the cable to the right between the cover plate and the edge of the center console, then left up over the steering column, out of the way of any moving parts and to the OBD port. I secured it with zip ties, of course. I have switched out my funky plastic "L" brackets with one made of aluminum. I originally fastened both the gauge to the bracket and bracket to the cover plate with Velcro. This was a bad arrangement, so the bracket is now screwed on to the cover plate, but the gauge remains Velcro'd to the bracket which makes it easier to remove for access as needed and avoids the need to do anything mechanical with the body of the gauge.
The colored plastic cover is nothing more than a red colored acetate school report cover that I got at a local stationery store. You can go with colored photo gel but it can be hard to find and is much more expensive.
Old Oct 22, 2014 | 02:46 PM
  #93
Kimbo80's Avatar
Kimbo80
Thanks for all your help! I will have to play around with the settings and swing by my local office supply store.
One last question is does your Ultragauge turn off automatically, or did you have to play around with the settings? The last thing I want is a dead battery, which was supposedly fixed on version 1.2
Old Oct 22, 2014 | 03:28 PM
  #94
Gambedegallina
It has been a while, but as I recall I used the default settings regarding powering on and off. The only settings I changed were the items to display on the pages. I was concerned about the power consumption issue based on posts on this site. I have had no issues whatsoever.
Old Nov 18, 2014 | 08:51 PM
  #95
jbat66's Avatar
jbat66
Yep, that is what I did. The color screen I used, is flash photography gel.
Just google "cto gel"
CTO = Color Temperature Orange
Old Jan 27, 2018 | 04:51 PM
  #96
Mini Clementine's Avatar
Mini Clementine
Reviving a dead thread? Well if anyone is still wondering if UG can drain your battery, yes it can. But I think I have a fix.
Here's my story (in short). Bought UG ex Ver 1.20. Plugged it in and set gauges. Turned car off and noticed UG screen stayed on... and on... so read manual and changed settings. Next morning, clock and date were zeroed and I got a pending P15E8 error code - likely due to draining battery.
Emailed UG, asked for settings for Mini Cooper. They replied it's impossible to drain battery. Reset it to factory settings - but then the screen stays on. So I think I have the settings right now.
Starting at p.45 of the manual so you can find your way around the UG.
Power ON detect - set to Mode 2
Power OFF detect - set to mode 5
Batt High threshold - set (or leave) at 13.2V - essentially tells UG to turn on when voltage is at 13.2V
Batt Low Threshold - set to 12.85 - tells UG to turn off if voltage is under 12.85V after you tried 4 times**
Power Off Retries - I set to 4 - tells UG if you find voltage is under 12.85V and you tried 4 times and it is still under 12.85V, turn off.
I put these settings and started the car with no clock/date issues after 8 hours sitting and again after another 24 hours sitting. Hopefully this does the trick and the code goes away after some time. I like the larger screen display and I've already made a nice mount so I'd like to keep the UG if I can.
Old Jan 27, 2018 | 04:53 PM
  #97
Mini Clementine
Apologies to Mods but I posted a reply here with settings for UG, but unknown reasons it was approved and posted and now it's gone.
Not trying to spam the forum. Just maybe not used to what happens.
Old Jan 27, 2018 | 09:18 PM
  #98
squawSkiBum's Avatar
squawSkiBum
Moderator
there were 3 copies of the same post, deleted 2. It's there!
Old Jan 28, 2018 | 05:50 AM
  #99
Whine not Walnuts's Avatar
Whine not Walnuts
For some strange reason once in a while the platform program that NAM uses will flag a post. Of the three you made, two were deleted and the last one was still flagged. I had to release the hold on it so it is now up there for everybody to see.
Old Feb 16, 2018 | 07:47 AM
  #100
Bnourai's Avatar
Bnourai
I got read of my scangage, now I run the OBD Wi-Fi and my IPAD mini with dash comand I can see all that I need on one page even my HPFP operations boost lambda speed rpm any info possible. but R56 OBD will not support oil temp or pressure.
Ben
