Interior/Exterior Remove Interior Trim?
Old Mar 11, 2011 | 08:30 PM
jkool44's Avatar
jkool44
Well I have been searching all afternoon, and cannot find anywhere a how-to for removing the grey rings around the speakers, air vents, and on the steering wheel. I want to remove them and either spray them or cover them in black vinyl. Has anyone removed these pieces before? Is it easy?
Any help is appreciated.
Thanks!
Old Mar 13, 2011 | 03:01 AM
Sketch's Avatar
Sketch
There is a how-to around here on how to remove the R56 trims you are talking about... Try to find it under 'chrome line retrofit' in the search section. The silver rings you are talking about are not easily removed from the larger pieces they are attacghed too. For example, the speedo ring is attached to the entire speedometer ring, so the entire cluster must be removed.
Old Mar 13, 2011 | 08:20 AM
jkool44's Avatar
jkool44
Thanks Sketch!
I found it in this thread: https://www.northamericanmotoring.co...e-changed.html
Anyone know about the steering wheel trim?
Old Mar 14, 2011 | 12:53 AM
AkFarina's Avatar
AkFarina
I think there are screws on the back of the steering wheel
wkp1219
Nov 13, 2015 07:52 AM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
xraycat
Aug 12, 2015 02:36 PM
