Interior/Exterior removing upper grille... need help
Old Dec 29, 2010 | 04:29 PM
TaylorL99's Avatar
TaylorL99
I am trying to remove the upper grille on my 06 MCS and am having some trouble. Everything i've read says this is very easy and all you do is remove the self taping nuts holding the grille in. I've heard you just use a flat head screwdriver to put pressure on the nut and remove them with a 10mm socket. I have tried this on two of the little posts, but I have stripped them both. Are there any tricks I should know? Any help would be appreciated!
Old Dec 29, 2010 | 04:49 PM
Vollgas's Avatar
Vollgas
I tried several methods that did not work.
Ended up using a Dremel tool to cut off the nuts. (Ouch)
Pins were ok.
Old Dec 29, 2010 | 06:49 PM
TaylorL99's Avatar
TaylorL99
what made you decide to cut off the nuts and not the little posts?
Old Dec 29, 2010 | 06:54 PM
Vollgas's Avatar
Vollgas
Wanted to be able to use grill again.
Old Dec 29, 2010 | 06:58 PM
TaylorL99's Avatar
TaylorL99
gotcha, so the new blackout grill does not need those little posts? If I didnt want to worry about using the old grill again, I can just cut off the posts and not worry about it?
Old Dec 29, 2010 | 07:22 PM
Vollgas's Avatar
Vollgas
Your new grill should have posts or some other latch system to hold it in.
OEM grill has latch as well as pins.
If you want to save grill for sale or other use, remove nuts.
Automated machines fastening metal nuts on to plastic studs.
Great engineering.
Old Dec 30, 2010 | 06:30 AM
N2MINI's Avatar
N2MINI
Just get the nuts off even if you strip the threads on the post if you reuse the grille just put some silicone on there inplace of the nuts...
Old Jan 1, 2011 | 10:16 AM
TylerF's Avatar
TylerF
If you can get the nut to unthread even a tiny bit, you should be able to get a flat head screwdriver between the nut and the hood and pry while spinning the nut. They should come right off at that point.
Old Jan 1, 2011 | 01:26 PM
Capt_bj's Avatar
Capt_bj
the posts are smooth. the fasteners are little self threading beasties that will happily spin in place until you apply a little back pressure to get them reverse threading back up the hill. They don't even need to be turned to be put on, they can simply be pressed down hence no threads to reverse up the hill 'til you make it bite. If you don't plan to re-use the grill just snap the posts off and recover the little fasteners - or buy new at ACE. Put a sheet over the engine compartment while working on this so you don't loose one .... wanna know how I know this can be a problem
I've installed several Aero Grill kits for folks, some wanted the grill preserved for reversal. Few own the car anymore and not one has come back to get the original put back.
Old Jan 1, 2011 | 08:55 PM
TaylorL99's Avatar
TaylorL99
thanks for the help everyone, it all worked out. I ended up getting the nuts off of the posts and the rest of the install (upper and lower grill) went very well. I would post a picture but the file size is too large
ltjpunk7
Sep 6, 2015 07:32 AM
sevin
12
Sep 4, 2015 01:50 PM
itsbrianyo
Aug 30, 2015 08:47 PM
greekzilla
Aug 23, 2015 03:44 PM
sleek55044
Aug 21, 2015 10:52 PM
