Interior/Exterior Interior Lighting Bulbs
Old Sep 1, 2010 | 09:50 PM
stt816's Avatar
stt816
i want to change all the interior lighting, such as the footwells,dome light, boot, and other things to a different color like blue or xenons. I went to autolumination.com but there are so many choices for #194 bulbs, i don't know which to choose. Are all of them #194? Will all of them fit? How many would I need? I rather do bulbs than LED strips, sounds like it is much simpler. Thank You!
Old Sep 1, 2010 | 11:17 PM
Mister-Aandrew's Avatar
Mister-Aandrew
Bulbs is the best thing to do for this setup. not sure about bulb sizes and stuff since i just reused the kit from my BMW, but i have pics of the setup in my gallery.
Old Sep 7, 2010 | 12:54 PM
stt816's Avatar
stt816
I have another question, I found a bulb that is 11mm diameter x 32 mm overall, would these fit in the foot wells and map lights?
Old Sep 7, 2010 | 10:37 PM
BlwnAway's Avatar
BlwnAway
When I did mine I used the xenon replacement bulbe for my dome, boot and floor. And the oval wide angle (single led) for my maps and bottom of my doors.
That being said while I really like look of the xenon bulb they're not real bright so you will loose some functionality (especially the dome light) also I did mine 4 years ago and the oval wide led was the only thing they offered that would physically fit for the map lights (also the xenon was the only fit for the dome) but that was then. They have a much larger selection now, with many more (and physically smaller) led selections to choose from.
Basically when I got mine the led's offered were physically larger and even though the connection may have been for a 194 socket the "bulb" (led) surface was to large for the application and now that may simply not be the case. (most of the time the issue is diameter more than anything else, cross refrence their size charts)
Basic rule of thumb led's will be brighter than the xenons in most situations. Also if you want any other color than the xenon white find an led that fits the colored bulbs will eventually burn the coloring off.
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
I_drive_slow
Aug 18, 2015 10:47 AM
AZN Optics
Aug 16, 2015 11:52 PM
