Interior/Exterior LED Stock Radio Mod *NOT COMPLETE*
Old Nov 16, 2011 | 09:01 AM
  #26
rustyeuro's Avatar
rustyeuro
does your dimmer switch next to the speedometer still work with the led change?
Old Nov 16, 2011 | 06:24 PM
  #27
westsideriderz15's Avatar
westsideriderz15
Yeah the dimmer works as it should. I used the computer paper trick for my tach today and it worked well. The numbers are hard to read however with my sunglasses on so a less opaque material may be needed. I changed 5 leds in the tacha nd left the needle orange. I think you cfan scrape the coloring off the needle if you need to make it a diff color. Just beware that youll have a clear needle during the day
Old May 9, 2014 | 04:44 PM
  #28
ThEgMaNofCourse's Avatar
ThEgMaNofCourse
has anyone found a way to bench test any of their mods without putting them back in the car?? ive got a tach and speedo that im modding (well practicing on before i mod the ones in my car) and id like to be able to at least get the LEDs lit so i can see if its a job well done or a complete failure. No worries, i have PLENTY of extra LEDs
Old May 9, 2014 | 10:37 PM
  #29
rkw's Avatar
rkw
Looking at the excellent wiring diagrams in the Haynes manual, the tach has ground on pin 5 of the connector, lighting on pin 4. Speedo has ground on pin 1, lighting on pin 14. Apply 12v.
Old Nov 16, 2016 | 10:20 PM
  #30
Blue_Coop_S's Avatar
Blue_Coop_S
Originally Posted by wyefye
It's not really peculiar at all; but expected. watch the size of your LEDs, you may find they don't fit if you chose the wrong ones.
good luck on the how-to, you saw how many steps there were for the radio... that's why i got lazy and didn't post the rest.
-Wyefye
p.s. way to revive a dead thread, hah.
hi i know this is an old thread but i tried to do my dash lights and i pretty much suck at it some light up and some dont, would you happen to know of someone in the NY/NJ area that is good at this?
Old Mar 21, 2017 | 02:04 AM
  #31
NewShockerGuy's Avatar
NewShockerGuy
Wow, the white looks so much nicer than the stock amber... It's 100x more cleaner looking!
-Nigel
sevin
May 2, 2026 06:11 AM
minimofo
Nov 16, 2016 05:56 AM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
