I was thinking about getting the real leather seats from a scrapper close to my house, they are also heated. Now would R56 seats fit in a R50 and would the heated seat option still work?
I have R56 JCW seats in my R53, so yes they will fit, but you need the rails and everything attached. Plugs are different on the R56 seats, so will need modifying to fit and work with your R50.
It's not clear whether an R50 seat rail can directly bolt on to the bottom of a standard R56 seat.
The short answer is that it isn't a direct swap, but probably can be made to work with enough effort.
Pretty sure the R56 seats wont bolt to the R50/523 seat rails. But the holes for the R56 seat rails are in the exact same place as R50/53 floorpan, so can be bolted down easily. Just need to mod the connectors on the seats to fit the R50/53.
Don't forget to get new bolts to attach the seats to the floor. They are your main line of defense in an accident and are intended as a one time use. Good luck with the new seats!
