Interior/Exterior Wood interior trim kit
Jim,
Those would seem to be the same pieces. Super. Maybe we could meet up sometime this summer. I can make an excuse for me to take a long Sunday drive. ( I am way the heck down in Bowie). Again, it is the "addition to main kit" that is just what I am looking for.
http://www.carid.com/2009-bmw-mini-c...tem-67618.html
Jim,
Jim
Jim
I went with the fake wood due to cost and not being sure how it was going to work out. You should do it in the summer and leave the kit in the attic for a few days, so the parts get very soft and bendable (They say you can use a heat gun, but that did not work well for me). The next most inportant thing is to clean the surface very well. When you think it is really clean, then clean it again. The outside edges are very important. They provide little sticks that have a liquid to make the adheasive bond better. Use them around all the edges of the surface you are mounting to. It is a two person job, so get some help. The only hard ones are the large, lower parts of the oval. Line it up, then get someone to hold one end (keeping it linds up and square) while you slowly pull the backing (a little at a time) and apply the opposite end. They will flex a little if you get off a bit. Go slow, as you only get ONE shot at applying them.
Jim
Jim
No problem. One other thing I forgot. I had no problems with any of the parts sticking a staying stuck EXCEPT for the passanger's dash cover. The top, left side tends to lift for some reason. I got them to send me a replacement part and it did the same thing. I solved the problem and you might not have the problem, but if you should I just put some glue under it, taped it down with masking tape and let dry.
Jim
Jim
07-16-2020 12:54 PM
