Interior/Exterior E-Brake Handle Replacement
Old May 17, 2010 | 09:06 AM
timfitz63's Avatar
timfitz63
I've been poking around the various forums looking for some guidance on replacing interior components, but have mainly uncovered discussions/instructions for the Mk I vehicles, not the Mk II.
When I purchased the vehicle used, my '09 JCW Clubman already had the alcantara/leather steering wheel upgrade, complete with a "JCW" carbon fiber insert at the 6-o'clock position (other two positions were ostensibly irreplaceable due to the radio/cruise controls). However, it still has the stock shifter **** and e-brake handle. Why someone went to the trouble of upgrading the steering wheel, and didn't bother with the other "driver" controls is a bit of a mystery to me...
Nevertheless, I've been contemplating doing this myself. At the moment I kind-of fancy the matching JCW alcantara shift **** & e-brake handle. I'm happy to leave the existing leather boots in place as (1) it's less work; (2) it's not as expensive as replacing the ****, e-brake handle, and the boots; and (3) keeping the existing leather boots kind-of ties the shifter/e-brake in with the leather in the JCW steering wheel. About the only thing that I wonder about with that set-up is how well the alcantara on these other components (and in particular, the shift ****) will wear, given the more direct handling they tend to get (steering wheel isn't as much of a concern for me, as I seem to routinely use a 2/10-o'clock hold on the steering wheel, and the alcantara covers more of the 12/6-o'clock regions of the wheel)?
From what I understand from other threads, the shift **** is relatively simple (although not necessarily easy): just pull up and hopefully it will "pop" off without Herculean effort. Not exactly clear about whether I need to clear/separate the boot from the ****, however. Some threads seem to imply the **** and boot are separate; others seem to claim the whole thing will come apart (potentially tearing the boot) if you don't take care to first separate the boot from the ****. So a little clarification there would be appreciated!
However, there doesn't seem to be much out there regarding the e-brake handle for the Mk II vehicles. What's the scoop there...? A cursory examination of the handle didn't reveal any obvious screws or releases to me, so I was reluctant to tinker too much before knowing where the potential pitfalls might be.
Old May 17, 2010 | 09:54 AM
Doug W's Avatar
Doug W
I recommend separating the boot from the console before yanking the **** from the lever. Then you can separate the shift **** from the boot; be advised, it's a PIA to get them apart.
The ebrake handle R&R is an easy 5-minute job; it's the same as on a 1st Generation car.
Old May 17, 2010 | 10:10 AM
CravenSpeed's Avatar
CravenSpeed
Vendor
The Gen 2 eBrake removal is a little easier than the Gen 1 IMO. If you have plastic body tools (to avoid scratches) that is best, but it can be done with two flathead screwdrivers too.
Just insert the driver on one side, near middle, of the plastic piece that the eBrake boot is attached to. Then put a second one into the other side and it will pop right out for you.
Old May 17, 2010 | 10:56 AM
Red-Mini's Avatar
Red-Mini
I went to redline goods and if you select your model that have installation instruction for gear shift and boots and e brake handles see sample -http://www.redlinegoods.com/MINI07install.shtm
Old May 25, 2010 | 07:29 PM
cop1406's Avatar
cop1406
I just pulled on the shift **** and it pulled the ****, boot and trim ring off all at once, which was perfect because I installed the Craven shift well cover.
boostedhaze
Jan 2, 2018 07:26 PM
nismo4life
Nov 4, 2015 09:18 PM
xpunisherx
Sep 1, 2015 11:47 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
wabiker3576
R55 :: Clubman Talk (2008+)
Aug 18, 2015 08:48 PM
