Interior/Exterior Dumb qauge wiring question
Old May 14, 2010 | 12:41 PM
gear-head's Avatar
gear-head
I have two gauges to install, Boost and Water Temp. They are Innovate Motorsports G2 gauges, silver with a clear lens.
Both gauges have these wires:
Black - Ground
Red - 12v (+) Ignition Source
Orange - connect to 12v (+) dash circuit for Amber back lighting
White - connect to 12v (+) dash circuit for White back lighting
(The water temp gauge also has Green for the sender's signal)
QUESTION: If I connect the Orange wire for 12v (+) so that I get amber back lighting at the same time as the rest of the dash, why would I also need the Red 12v(+) from the ignition?
Old May 14, 2010 | 06:50 PM
rjb's Avatar
rjb
The red +12v ignition powers the gauge , the +12 volt for the lighting only powers the LED back light
Old May 14, 2010 | 07:12 PM
gear-head's Avatar
gear-head
OK, the temp gauge, I can understand needing to be powered, but the boost gauge? It works if I blow down the hose.
Old May 15, 2010 | 08:45 PM
Fatherdeth's Avatar
Fatherdeth
The boost gauge still needs to light up at night. The black is ground, and the orange will allow it to dim with the OEM gauges. Red should be main power.
Old May 16, 2010 | 11:58 AM
gear-head's Avatar
gear-head
Got it all working, thanks.
Old May 18, 2010 | 08:28 AM
gear-head's Avatar
gear-head
Innovative G2 gauges match perfectly
got 'er done
Old May 18, 2010 | 08:40 AM
Whiner's Avatar
Whiner
Looks good!
bcman
Aug 28, 2015 04:47 PM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
Getrieben
Aug 15, 2015 09:09 PM
yashmack
Aug 15, 2015 03:11 PM
