Interior/Exterior Wheels offset
Old Apr 15, 2010 | 07:00 AM
ja5on's Avatar
ja5on
Wheels offset
Anyone has 17 x 7.5 ET35 wheels on their r56? Any rubbing? Or more advisable to go with ET40?? Thanks
Old Apr 15, 2010 | 07:07 AM
slinger688's Avatar
slinger688
If you are afraid of the tire rubbing on the shocks then you need ET35. If you are rubbing the outside wheelwell, then ET40 is better.
Take a look at this: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Jun 4, 2010 | 12:46 AM
adam_randell's Avatar
adam_randell
I am going to be getting some 17x8 wheels with an ET35. What tyres should i get and will it rub with the car dropped 55mm?
Old Jun 4, 2010 | 01:14 AM
joshknot's Avatar
joshknot
For what it's worth, I ran 17x7.5 ET35 with 215/45-17 tires and had rubbing issues front and rear on stock suspension. If you're willing to adjust the camber, you may avoid the issue- but it was enough of a problem that I nixed the setup and moved on to a more conservative setup (17x7 ET40 with 205/45/17- call it an overreaction if you will, but it works great).
Old Jun 4, 2010 | 01:26 AM
adam_randell
ah amn. I really really wanted these wheels, but the car will be dropped at least 55mm so if you rubbed with stock suspension i have no chance!
Old Jun 5, 2010 | 10:30 AM
tvrgeek's Avatar
tvrgeek
Very nice web site. They actually have the wheel weights listed. Some very tempting 16 x 7 wheels. I don't know the brands so I need to check on them. If the 205's I plan don't cut it, then I will need some 7 inch rims to go 215's.
Old Jun 5, 2010 | 10:38 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
My car is super low and I have no rubbing issues with 17x7.5 et35's. There are a bunch of us running similar specs without rubbing. Just need to be careful with tire selection.
7.5j et35 is very conservative. Don't worry yourself too much over it.
Run 205/40/17 on the 17x8's and you'll be golden.
Old Jun 5, 2010 | 10:55 AM
adam_randell
Beautiful! Thanks a lot mate. That's the tyre I went for in the end! Can't wait to get the whhels on now!!
SosoMINI
Nov 22, 2015 03:17 PM
madmax88
Oct 26, 2015 01:45 PM
StuRat
Aug 24, 2015 06:24 PM
Mini'mon
Aug 16, 2015 04:15 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
