Interior/Exterior Will Alta filter fit on Dinan Box?
Old Feb 17, 2010 | 11:13 AM
burley's Avatar
burley
Want to buy the Dinan, but dont like their disposable air filter... Any know if I can use my current Alta V2 air filter?
Old Feb 23, 2010 | 04:15 PM
burley's Avatar
burley
bump
Old Feb 23, 2010 | 05:22 PM
ZippyNH's Avatar
ZippyNH
The best way might be to check to see if they both use the same "universal" replacement filter model from K&N.....that way if the neck size on the filter matches, and the length is compatible...it would.
My bet is no...due to the fact there are thousands of possible combinations.
Do a quick search on this site...the Dinan K&N filter # is floating around....then measure yours...see if it matches up with the important diminsions on the K&N website....and see if it is a match.
NO PAIN, NO GAIN....time to do some work!!
The Dinian filter is actually pretty good by the looking at it...most likely a K&N copy.
The Dinian filter does have a crooked neck (rubber part) that connects to the intake to situate it correctly in the air-box (this also lets them fit a much larger filter in the air-box).....the K&N replacement lacks this...and as a result from what I have seen, it is a bit smaller....maybe it flows less, or will need to be cleaned more often.
Do you just want to use a foam filter?!
If you do, MinSpeed was the seller of an ITG foam filter for the Dinian intakes....Minspeed is now closed...and the part was a custom part for them....somebody bought their old stock.......and soon I believe one of our current vendors may start selling some items from Minspeed. In the meantime, I think you are out of luck!!
Old Feb 23, 2010 | 05:34 PM
tito's Avatar
tito
ITG offers a good replacement for Dinan. I use ITG for my Dinan.
Old Feb 23, 2010 | 05:54 PM
ZippyNH's Avatar
ZippyNH
RU-1460 K&N is the filter from K&N
Old Feb 23, 2010 | 05:57 PM
ZippyNH's Avatar
ZippyNH
Part RU-1460 Product Specifications Product Style: Round Straight Universal Air Filter
Flange Angle: 10 degrees
Flange Inside Diameter: 2.75 in (70 mm)
Flange Length: 1 in (25 mm)
Flange Type: Angled
Height: 5 in (127 mm)
Outside Diameter: 4 in (102 mm)
Top Style: Rubber
Top Material/Finish: None
Filter Material: Cotton Gauze
Filter Re-Oiling Amount: 0.55 oz (16 ml)
Flanges: 1
Inner Wire: No
Weight: 0.8 lb (0.4 kg)
Product Box Length: 4.63 in (117 mm)
Product Box Width: 4.63 in (117 mm)
Product Box Height: 7.25 in (184 mm)
http://www.knfilters.com/search/prod...x?Prod=RU-1460
K&N's Universal Air Filters are designed and manufactured for a wide variety of applications including racing vehicles, radio-controlled cars, generators, snowmobiles, tractors, and other applications. Regardless of the angle or offset diameter of the air intake, there is probably a K&N Universal air filter for your equipment. All filters are constructed with ultra-strong molded pliable rubber flanges which absorb vibration and allow for secure attachment and can also be stretched for up to 1/16" (1.5mm) to fit in-between sizes. K&N universal air filters are washable and reusable.
Old Feb 23, 2010 | 06:00 PM
ZippyNH's Avatar
ZippyNH
Now all you need to do is measure your Alta filter and see if it is the same, or at least similar enough to fit!
Good Luck!!
Old Feb 23, 2010 | 06:02 PM
ZippyNH's Avatar
ZippyNH
Who still sells it?!
The ONE place that used to sell this filter that I knew of is closed....Minspeed.
Does somebody else still sell them?!
Old Feb 23, 2010 | 06:15 PM
burley's Avatar
burley
Good Luck!!
Hey, thanks for all the help! I just need to wait for my wife to get back with the "Dudley" so I can measure the filter.
Old Feb 25, 2010 | 07:10 AM
ZippyNH's Avatar
ZippyNH
Just for future reference for somebody else with the same question....what is the result?!
Old Feb 25, 2010 | 07:17 AM
burley's Avatar
burley
it was very snowy last night... I'll check today.
Old Mar 17, 2010 | 08:19 AM
burley's Avatar
burley
Just got a measurement from Alta (since my wife always has the Cooper) and according to them the diameter of the inlet is 2.75 inches.
Looks like the K&N filter will fit on the Dinan airbox. Being that that'll cost another $200+, I think I'm either going to saw off the Alta V2 connection piece (from the sheet metal box) and attach it to the OEM stock air box (after some cutting of the box) so it seals. This is a free mod (since I've already purchased the alta). If that doesn't get rid of the whistle, then I'll go Dinan/K&N. Does that makes sense?
Old Mar 17, 2010 | 08:41 AM
ZippyNH's Avatar
ZippyNH
The dininan is a lid that goes on the oem box....you also want to have the back pannel that is usually ripped out during Alta installs re-installed.....have you seen the dininan box yet? It is mostly an either/or propostion. The oem air intake tube is also reused on the dininan....it makes for a nice, insulated, cold air intake with a well defined intake path, and just a bit more noise than the JCW...perfect for longer drives.....
AWOL
Mar 28, 2016 10:51 AM
pocari
Jan 1, 2016 05:46 PM
stierzy34
Sep 15, 2015 04:40 PM
M7Speed
Aug 6, 2015 01:48 PM
