Interior/Exterior Fitting R56 Aerokit to R53
Old Apr 7, 2010 | 04:23 PM
  #26
kipperhughes's Avatar
kipperhughes
hope costa316 wont mind me posting what he wrote on m/u as it answers your questions:
Actually yes!! The first stage in which we took the old aero skirts off and fitted the new r56 skirts on went really well. The only problem(if you want to call it a problem) is that the r56 flares are wider than the r53. So, we decided, lets paint the skirts, fit and install them this week, and if the difference in width is too much, then we would sand down a portion of the flare and paint it body colour in order to make the flare appear the same size. A few minor trims were needed in the door sill section, and since the r56 had more plastic clips then the r53, we just cut them off. Other then that lenght and depth were bang on...
There were several little problems that we had to deal with.
First, the door sills needed some small trimming in order to sit right.
2nd, the only plastic tabs that alligned perfectly were the ones on the door sills. Most of the other ones, did not allign, so we had to secure them using metal rivets (I beleive that's what they are called).
3rd, the top lip of the skirt that goes underneath the door was thicker than the original skirt, so we had to shave that down to size.
All in all, if you have a good autobody guy, it can be done. Just takes a little time and effort.
Old Apr 8, 2010 | 09:09 AM
  #27
XXLil MickXX's Avatar
XXLil MickXX
Originally Posted by kipperhughes
I have a set on my car they really do just set it off much better than the plastic oem grills
Do the twin scoops have a grill inside of them? or does it fit over the existing scoops? Your car looks great!
How much are the R56 side skirts?
Also, is that the aero front bumper or something different?
PS Is it a lot of work to do that steering wheel relocation mod?
Old Apr 8, 2010 | 10:02 AM
  #28
kipperhughes
the scoops have tiny metal mesh grills in them and you pop out your old oem plastic grills and replace them with these easy to do just fiddly. thanks! she nearly how i want her to look just need some more money now
in UK they about 200 quid or cheaper if you find some going second hand but they hard to find second hand.
its a standard s bumper with a trim i got off ebay not sure if the seller still has any left he did have a limited supply last time i checked.
im from UK so its not a mod
Old Jan 13, 2011 | 08:17 AM
  #29
IsquintsI's Avatar
IsquintsI
Dope! I wish i had a mini cooper s instead of a standard!
Old Aug 11, 2011 | 10:59 PM
  #30
Carbonbaby's Avatar
Carbonbaby
Originally Posted by KC Jr 54
Anymore photos of that flat black Mini ? Thing looks nasty!!
I'm find only video http://vimeo.com/5576376
Old May 14, 2014 | 03:53 AM
  #31
Striped Toad's Avatar
Striped Toad
Are there any photos of the door sills that have been modified?
Or any features/pics of this MINI?
Old Dec 13, 2015 | 08:25 AM
  #32
Eurothrasher's Avatar
Eurothrasher
The aero side skirts for 1 gen and 2nd gen share exact same parts you can't see. If you want to add R56 side skirts to R53 you need get the aero mounting sill adaptors and then all mounting points under the car will match up. Trimming will be required for kick plate area due to slight differences in door sill ends.
Get door sill adaptors right and left side about $31.00 per side.
Part no # 51 71 0 413 260
Part no # 51 71 0 413 259
Then will just need the standard hardware for aero kit installation for R53, runs about 30 dollars a side for clips and hardware.
Old Dec 14, 2015 | 11:00 AM
  #33
Looks like this : 51710413260 51710413259 for the R56 to R53 conversion.
https://www.ecstuning.com/Search/Sit...h/51710413260/
https://www.ecstuning.com/Search/Sit...h/51710413259/
Old Oct 23, 2023 | 05:57 AM
  #34
OutlandishnessDue's Avatar
OutlandishnessDue
Late to the game, but this thread really helped! With the adapters, everything snaps into place no problem. There's really nothing you can do about the fender trim not being as wide, but IMO doesn't really matter.
Old Oct 23, 2023 | 07:27 AM
  #35
Awesome congrats!
Old Nov 8, 2023 | 12:32 PM
  #36
Just an update those 2 parts are now NLA from MINI 51710413260 51710413259 and only available at ECS now in aftermarket! Linked above. We just landed more stock.
If you have the side skirts.
Otherwise get this full kit with them.
https://www.ecstuning.com/Search/Sit...w_side_skirts/
And you can do this also.
Gloss black side trims :
https://www.ecstuning.com/b-ecs-part...10445884gb~ec/
https://www.ecstuning.com/b-ecs-part...10445883gb~ec/
MiniManAdam
14
Sep 3, 2021 07:19 AM
minihooligan773
May 19, 2015 09:26 AM
WannaMini_
Tires, Wheels, & Brakes
Aug 12, 2009 10:16 AM
northsidetackler
May 3, 2009 10:26 AM
