Interior/Exterior Adjust headed seats
Old Jan 5, 2010 | 09:42 PM
burley's Avatar
burley
Adjust headed seats
Is there any way for either me or the dealer to adjust the headed seat levels? It seems much cooler than on my last cooper, and I'd like to crank it up a notch. If its adjustable, how?
Old Jan 5, 2010 | 09:47 PM
glnr13's Avatar
glnr13
my heaTed seats go to eleven
Old Jan 5, 2010 | 10:23 PM
rkw's Avatar
rkw
There is a service bulletin to adjust the heat level. Your dealer should be able to handle it. See this: https://www.northamericanmotoring.co...Adjustment.pdf
Old Jan 6, 2010 | 07:36 AM
burley's Avatar
burley
Hmm at the bottom of the service bulletin it says, "Reimbursement is limited to 36 months/100 000 km and only possible until March 2007."
Wonder is they can still perform this and if they'll charge me now.
Old Jan 6, 2010 | 09:15 AM
rkw's Avatar
rkw
Of course they'll charge you! The '04 in your sig is out of warranty. But even if you were still in warranty, MINI will not reimburse a dealer for performing the service after that date.
You can check if the adapter cable (part# 61 10 0 152 026) is still available, and install it yourself. The replacement seat cover they mention (if you don't have it already) would be quite expensive.
Old Jan 6, 2010 | 09:58 AM
burley's Avatar
burley
I've had MINI dealerships perform work for free outside of my warranty. Im not sure if it was a recall or service bulletin. Is there a difference?
Old Jan 6, 2010 | 10:20 AM
rkw's Avatar
rkw
It's not a recall. It's a "do this only if a customer complains" service bulletin. MINI will no longer reimburse a dealer for this issue, so at the very least you'll have to pay for the part.
Old Jan 6, 2010 | 10:52 AM
ZippyNH's Avatar
ZippyNH
It is possible that they could "Good Will it". Not likely, but if you have a good relationship, it is possible....though unlikely. You never know....
Old Jan 6, 2010 | 11:02 AM
burley's Avatar
burley
Is it something I could do myself or have a local imports garage do?
Old Jan 6, 2010 | 11:11 AM
ZippyNH's Avatar
ZippyNH
Sounds like you need to buy a part from MINI at the very least. Might be possible to rig with a rheostat....but might not be worth the risk of frying or lighting something on fire!!!
Old Jan 6, 2010 | 11:15 AM
ZippyNH's Avatar
ZippyNH
Print up that file from nam....I bet you could diy it...or if give it to a guy at your place could do it pretty quick with the instruction if you supply the part!!
eatsleepautox
Oct 30, 2015 06:46 AM
Zettinger
Aug 25, 2015 04:04 PM
jziran
Aug 24, 2015 04:50 PM
MIminiclubman
Aug 5, 2015 09:14 PM
