Interior/Exterior Truck Horn
Old Jan 5, 2010 | 11:08 AM
malteseracer's Avatar
malteseracer
Truck Horn
So I've decided that rather than go for another performance mod to do something totally different next.
http://www.kleinn.com/products/102.htm
http://www.kleinn.com/products/6250.htm
Anyone have idea for mounting location? I was thinking of doing it in the back of the car under where the boot is but I'm not sure. I haven't bought the system yet or have the car up in the air to test clearances. Just a feeler at the moment.
The only major problem I see about the back, assuming clearance isn't an issue, is that the nipple for the wiring to go to a switch inside is under the bonnet and I would need to tie up a lot of wire to get from the back, into the bonnet, then into the car. Is there and rear mounted grommet I could use?
Old Jan 5, 2010 | 11:16 AM
drewstermalloy's Avatar
drewstermalloy
I have a truck horn hanging in my basement and the rest of the system somewhere. If you do it, keep us updated. I've been wanting to put that thing on my cars since I got my license.
Old Jan 5, 2010 | 11:19 AM
malteseracer
I'll def keep you guys updated. It seems like an easy install, but space is at a premium in the car.
Old Jan 5, 2010 | 12:28 PM
AggieMini11's Avatar
AggieMini11
I saw a thread where I guy did this. Do a search. It was really funny and it was an extensive thread on how and where to do it on a 1st gen.
He ran a cable pull up to around his shifter. The horns were mounted in the engine compartment, i believe just stuck up under there.
Old Jan 5, 2010 | 01:28 PM
trwxxa's Avatar
trwxxa
You're going to be one of these guys, aren't you?
http://vids.myspace.com/index.cfm?fu...eoID=733212696
Old Jan 5, 2010 | 02:03 PM
Capt_bj's Avatar
Capt_bj
I just put a set of these in my 79
http://www.stebel.it/stebel2009/prod...logia=musicale
mine R the River Kwai .... curious sound
but not easy to mount
Good source for a lot of horns ....
http://www.autobarn.net/horns.html
but you can also find a bunch at your local Harbor Freight too . . .
Old Jan 5, 2010 | 07:37 PM
Some Guy's Avatar
Some Guy
This is the thread you want. https://www.northamericanmotoring.co...e-extreme.html
CO2 or HPA is the way to go, far less space hungry then a compressor and tank.
martinb
Oct 7, 2015 05:00 PM
krohm
Sep 28, 2015 12:16 PM
one73ronin
23
Sep 22, 2015 09:56 AM
The Rossness
Sep 17, 2015 03:06 PM
