Interior/Exterior Chrome side vent grilles problem
Old Nov 4, 2003 | 10:26 PM
SilentRage's Avatar
SilentRage
I recently bought the chrome side vent grilles from Moss Mini. They look great, the only problem is that they keep popping off when I'm driving. It's become a big pain in the butt. Installation was fairly simple... pop the old vent out, pop in the new. I made sure it snapped in and everything. Has anyone had this problem before and does anyone suggest a fix or is this just a product defect? I'm attaching a pic of the side vents...
Old Nov 5, 2003 | 08:31 AM
retroom's Avatar
retroom
The plastic grommet that the front of the grill snaps into may be positioned too far away from the grill mount preventing a complete connection. Try this...when pushing the grill into the grommet place counter pressure on the opposite end (the end inside the fender) this should ensure a tight fit. I had the same problem with my grill popping out doing this solved it.
Worst case, get a new grommet from the dealer.
Good Luck,
retroom
Old Nov 5, 2003 | 12:11 PM
Xanthus's Avatar
Xanthus
Coordinator :: South East - Florida
I used a little clear sillicone gel. I know that removing them now will likely break them, but mine no longer pop out.
Click on the image to see more of my Mini.
Old Nov 5, 2003 | 01:00 PM
ChiliCooperMark's Avatar
ChiliCooperMark
I used retroom's counter-pressure method and it worked fine. The grommet is on a bendable metal tab. Be aware, though that if you bend the metal tab too far towards the outside of the car, then your grill will stick out, with a gap between its edge and the car body.
Old Nov 5, 2003 | 05:17 PM
retroom's Avatar
retroom
Yeah, you don't want to bend the metal. I'm glad it worked for you.
retroom
Old Nov 6, 2003 | 04:53 AM
ChiliCooperMark
... I should have added that when I did get this "gap" problem, it was a simple fix to just bend the metal tab again, back away from the outside of the car.
wkp1219
Nov 13, 2015 07:52 AM
mcoopers81
Aug 19, 2015 01:42 PM
cm.d
Aug 19, 2015 08:51 AM
