Interior/Exterior 2003 MCS DIY OBC worked!!!
Old Sep 25, 2009 | 11:32 AM
GumbyLara's Avatar
GumbyLara
Well, it worked!!! This morning I wired in my switch to my harness behind the speedo using this DIY
http://www.mini2.com/pdf/onboard_computer.pdf
After I had it wired and ready to go, I drove over to Momentum Mini and asked if they would activate the OBC, at first no one new what I was talking about and the guy I spoke with on the phone yesterday was like "we will call you to see if it works, then you can come back" but I already drove the 1 hour drive so it was getting done. Finally the tech came out and I explained to him that I already have the Xenon headlights which requires the harness, therefore the hardware is there, it just needs to be programmed, I also asked him to shut off my daytime running lights and then he kind of understood what I was talking about with the OBD2. After 20 min, he came back out and said "it can be done but they want to charge you for an hour which is 130 bucks!" and then it happened, "but I will do it for 20" and I was like, done. Lol. So he did it and boom! My button worked! Only thing I am kind of upset about is that for some reason I still don't have digital speed? But oh well, I have everything else!
Old Sep 25, 2009 | 11:48 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
The earlier first gen cars never had 'current speed.'
Old Sep 25, 2009 | 12:05 PM
GumbyLara's Avatar
GumbyLara
Yeah, I figured it was something like that, Cause the 04' I drove for a little had the digital speed but this one doesn't, oh well! It's still a nice feature for 20 bucks instead of 200!
Old Sep 28, 2009 | 07:11 PM
jbell's Avatar
jbell
wait? i can do this on my 04s?
i have the button on the hedlight stalk. do i still need to add a button?
Old Sep 28, 2009 | 07:54 PM
GumbyLara's Avatar
GumbyLara
You should just need to get it activated from the Mini Dealer
Old Sep 29, 2009 | 07:57 AM
Bigshot's Avatar
Bigshot
What does the button do for you now?
Old Sep 29, 2009 | 08:47 AM
jbell's Avatar
jbell
shows speed and temp.
Old Sep 29, 2009 | 03:36 PM
Bigshot's Avatar
Bigshot
So in other words just what the newer ones showed stock.
By the title I thought it was getting more of the OBC readouts available.
Old Sep 29, 2009 | 06:41 PM
jbell's Avatar
jbell
likewise. :(
Old Sep 29, 2009 | 07:32 PM
GumbyLara's Avatar
GumbyLara
It is, I get average speed, how many miles I have left to a tank, average miles her gallon, and temp. As before I installed the button it was only temp. My model mcs can't get the digital speed because I don't have the sensor. I have the obc1 and the newer mini's have the obc2
Old Sep 30, 2009 | 07:09 AM
Bigshot's Avatar
Bigshot
So your MINI did not come with the stalk button?
And then you had the dealer flash the car to get the OBC readout to work?
Will this same thing work for later cars that already have the button?
Old Sep 30, 2009 | 07:23 AM
GumbyLara's Avatar
GumbyLara
Exactly! That's what I did, it should work as long as you have the correct hardware. Since you have the button then they should just be able to enable it.
Kimolaoha
Jul 5, 2023 01:04 PM
thebordella
Aug 31, 2015 01:37 PM
PrimePower
Aug 16, 2015 06:29 PM
PrimePower
Aug 11, 2015 12:51 PM
joelcseymour
Aug 7, 2015 12:43 PM
