Interior/Exterior New Panel Beneath Toggles
Old Feb 1, 2010 | 03:43 PM
  #26
MaxMini81's Avatar
MaxMini81
Wanderer
Thanks! I get proud of my creations. The initial design was nice because the toggle switches resembled the toggle bank above. However, the scangauge is flush mounted by a piece of 90 degree aluminum that attaches where the indicator lights I'd planned to include were to go. After I two other panels made two other panels in an attempt to make it all work, I decided to dump that part of the plan. I was so conscious about turning off the radio switch that I often neglected to even look at the other switches. After leaving my light bar on three times and completely killing my battery, I decided I had to find a middle ground. Then when the power supply wire came loose and I no longer had a radio, I had to act. The wiring harness had to be addressesed, and the solution is an incredible improvement, but took some serious time to setup the pin clips. The switches were chosen because those were the only ones radio shack had 5 of. All in all I really like this version more, but one switch has a non-functional light which will have to be addressed soon.
Old Feb 4, 2010 | 07:01 PM
  #27
OhBlueS's Avatar
OhBlueS
Awesome job, looks sweet. Nice one off piece.
Old Feb 8, 2010 | 11:37 AM
  #28
littlecS's Avatar
littlecS
wow nice job!
maybe take those cupholders and turn them into some kind of gauge holder?
kind of down and out of the way, but its usable space perhaps?
Old Feb 10, 2010 | 12:46 PM
  #29
MaxMini81's Avatar
MaxMini81
Wanderer
Originally Posted by littlecS
wow nice job!
Yeah, I put a lot of consideration into it all but never really came up with anything that I really thought would look better than just covering them up. As for the gauge idea, well I moved the head unit into the glove box and built another panel for up there.
Old Feb 10, 2010 | 05:14 PM
  #30
littlecS's Avatar
littlecS
oo...much better!
looks like it could be in a track only car without the radio.
Old Mar 1, 2010 | 06:51 PM
  #31
MyMiniGidget's Avatar
MyMiniGidget
Max did you paint or put vinyl on your down tubes? And if its vinyl where did you order it?
Old Mar 1, 2010 | 08:21 PM
  #32
MaxMini81's Avatar
MaxMini81
Wanderer
Its engine enamel. The stuff is practically armor. I sprayed multiple layers of primer, sanding smooth between coats. Then a couple coats of like Ford Mustang red and sanded smooth. Next were multiple coats of red and, because of the location, like 8 coats of clear coat.
Old Mar 18, 2010 | 05:22 PM
  #33
philz's Avatar
philz
I love that, looks fantastic. Great work
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
