Interior/Exterior Glove box won't stay closed!
Old Oct 15, 2003 | 06:49 PM
Grahambo's Avatar
Grahambo
Every other bump I go over and my glove box falls open. I did some poking around the latch and hook area but I didn't see anyway to make any sort of adjustment that might fix my problem.
Anybody heard of this problem, or have an idea of how to fix it.
Thanks!
Old Oct 15, 2003 | 07:02 PM
JakeBRG's Avatar
JakeBRG
I had the same problem–the slightest bump would set it off. Took it the dealer–they fixed it no problem, no charge.
Now I go over railroad tracks and it stays closed no matter what.
Old Oct 16, 2003 | 11:49 PM
Minimad's Avatar
Minimad
My wife's LY/Bl had the same problem. I'm waiting for the 10K service to have the dealer repair it properly. There is an adjustment to the catch (you need a torx) but that didn't fix it. As an interim fix I placed a small 3/4" wood spacer above the catch (between the case of the glovebox and the dash above) to lower it. That did solve the VERY IRRITATING problem, for now.
Old Oct 17, 2003 | 01:57 PM
mburchill36's Avatar
mburchill36
Yeah - I had the 'glovebox issue' too... So far, it's the ONLY issue I've had :smile:
Anyway, I just took it down to my dealer and they pulled out the 'loose' glovebox and installed an new one - no charge - covered by warranty. Only took about 20 minutes....Give your dealer a call. Good luck!!
- - Michael
Old Oct 17, 2003 | 02:10 PM
rg's Avatar
rg
I'm guessing you've already tried duct tape!?
I'd say the best solution is the dealer, it's their problem, let them fix it. Get your money's worth out of them.
Old Oct 17, 2003 | 02:48 PM
Eags's Avatar
Eags
Bryan Eagle
Terry Sayther Automotive
Austin, TX
www.terrysaytherauto.com
Old Oct 20, 2003 | 08:22 AM
Grahambo's Avatar
Grahambo
Thanks for all the feedback. While my dealer isn't that far away I was hoping to avoid having to avoid the hassle of taking the time to go there.
I did a bit more poking around in the latch area and I noticed that there are two rubber "bumpers" behind the outside latch handle. If I put some pressure on the handle I could make the latch move into a more tight fitting position but then the bumpers would just push it back out of position. So what I decided to do was cut about a 1/4" off of each of the bumpers, and lo and behold, no more glove box falling open problems.
cawwwtun
May 3, 2016 08:03 AM
ROCNDAV
Oct 20, 2015 01:08 PM
blackie
Aug 23, 2015 08:44 PM
Chasp
Aug 22, 2015 01:26 PM
