Interior/Exterior Help - Joey Mod Taillights
Old May 26, 2009 | 12:11 PM
blackX5's Avatar
blackX5
Hey guys - anyone have access or links on where to find step by step instructions on joey modding taillights for an R53? Tried searching for it with no luck.
Old May 26, 2009 | 12:38 PM
BlimeyCabrio's Avatar
BlimeyCabrio
1) remove tail lights - it's a nut and a couple of clips, and a plug.
2) use a dremel tool with cutoff wheel and go completely around the light where the lens is glued onto the black body of the light
3) use a razor knife to clean up the melted plastic on both pieces
4) use painter's tape to mask off everything except the chrome you want to black-out
5) paint or plasti-dip (if you plasti-dip, you need to score around the edge of the chrome where it meets the tape after each coat - 3-4 medium wet coats 10 minutes apart). Allow to dry WELL.
6) remove tape
7) make sure you have no fingerprints or dust inside the lens
8) glue lens back in place using epoxy or black silicone. CAREFUL - don't get any adhesive on the lens!!!
9) reinstall and enjoy
Old May 26, 2009 | 10:46 PM
Jtrem's Avatar
Jtrem
Well if you wanna do it Em. I have a dremel
Old May 27, 2009 | 12:29 AM
4Boogie's Avatar
4Boogie
all throttle no bottle
just a few additions to directions above.
-cover lenses with tape before you start to prevent scratching or getting stray epoxy on them
- Use 5 Min. epoxy with the self mixxing needle to close them back up. You dont want to try to mix epoxy and smear it on, that aint gonna fly.
- when you have them back together go back around the seem with epoxy to make sure they are water tight.
Old May 27, 2009 | 04:17 AM
BlimeyCabrio
Good tips... I did NOT cover my lenses first and wish I had...
And I did the mix and smear epoxy - worked OK, but the needle woulda been easier... especially after I dropped one of my lenses in the epoxy and took 2 hours to wetsand and polish it back out.
OutMotoring
Mar 3, 2017 06:29 AM
bahman
Feb 14, 2016 10:29 AM
GAT
Oct 4, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
Alpha Motoring
Oct 1, 2015 10:30 AM
