Interior/Exterior Fog lights!!!
Old Mar 30, 2009 | 09:05 PM
kevin barrett's Avatar
kevin barrett
Fog lights!!!
I just got a very low mileage 06 cooper s, loaded, loaded, loaded. It has front and rear fog lights. I cannot see the difference when they are switched on or off. Are they broken or is there some trick I am not aware of, please illuminate me[no pun intended].
Old Mar 30, 2009 | 09:44 PM
mitch171's Avatar
mitch171
Headlights have to be on and on low beam.
Old Mar 31, 2009 | 03:30 PM
kevin barrett
I'm an idiot.
Old Mar 31, 2009 | 04:00 PM
Malcon's Avatar
Malcon
haha. not to worry. most of us are also.
Old Mar 31, 2009 | 04:07 PM
iwashmycar's Avatar
iwashmycar
so is that new on the r56.. i only need parking lamps for my fogs... i guess i DO need headlights for the rear ones tho
Old Mar 31, 2009 | 05:03 PM
mitch171's Avatar
mitch171
I am not sure about the rears, but on my r50 you are right it just needs to be clicked to parking lamps.
Old Apr 1, 2009 | 06:54 AM
H82WRK's Avatar
H82WRK
you can also confirm that they are on by the wee tiny green light at the end of the toggle
Old Apr 1, 2009 | 11:31 AM
minjae's Avatar
minjae
honestly the factory stock fog lights dont go very far and you kinda have to look over your steering wheel to actually see the light on the ground.
I did, though, put H9 bulbs instead of the H11 bulbs after a bit of modding. As they are a bit brighter.
and yeah..when you use high beams the fog lights turn off
Old Apr 1, 2009 | 11:52 AM
Jahmills's Avatar
Jahmills
Well just the parking lights have to be on, at least on mine.
Old Apr 2, 2009 | 01:54 AM
Eric_Rowland's Avatar
Eric_Rowland
Originally Posted by kevin barrett
I'm an idiot.
But we still like you.
As stated, you only need the parking lights on. And no, they're not very bright.
Old Apr 2, 2009 | 07:37 AM
MoxieMini's Avatar
MoxieMini
+1.
Setting it on parking lights should do the trick. Unless they changed something between 03 and 06.
Old Apr 8, 2009 | 12:38 AM
07BPB's Avatar
07BPB
Fun fact for you: In Australia the Mini's can have their parking lights, headlights, front fogs and high beams on all at the same time. Turning on the high beams does not turn off the fogs. After reading this thread I had to double check and sure enough.
Old Apr 8, 2009 | 07:13 AM
minjae's Avatar
minjae
that's pretty interesting..
but that's not fair..
Old Apr 8, 2009 | 09:32 PM
07BPB's Avatar
07BPB
Neither is the exchange rate
Sep 28, 2021 01:16 PM
Aug 21, 2015 12:58 PM
Aug 21, 2015 12:50 PM
Aug 19, 2015 12:51 PM
