Interior/Exterior OEM E92 M3 Rear LEDs fitted
Old Feb 21, 2009 | 11:19 AM
jayxx83's Avatar
jayxx83
First up I took of the rear number plate plinth. Was an easy job as it was just 4 x torx bolts and unclipping the electrical wires. (excuse the piccys used the compact as I couldnt be bothered with the SLR)
car needed a wash hence the dirt.
used these bits, although the bullets werent needed in the end.
Was a very tight fit and had to trim the oem plinth quite a bit and the new lights to get a flush fit.
In the end I managed to do it and wired them up. It didnt work first time but some rewiring later it functioned correctly and the boot popper was working once more.
Siliconed them into place so they fit flush and were water tight...
And volia... sorry didnt have time to wash the car.
far better than the ebay tat!
Old Feb 21, 2009 | 12:28 PM
UKSUV's Avatar
UKSUV
I thought you grafted in E92 tail lights....LMAO. That would look cool. Good job on that tho...looks good!
Old Feb 22, 2009 | 10:08 AM
Willy_sa's Avatar
Willy_sa
I just got Led replacment globes that fit in the oem brackets. also works but big up, that looks good and wil probably last longer. Will post pics if i ever get to taking some.
Old Feb 22, 2009 | 05:01 PM
jerjer's Avatar
jerjer
wow, all that work?
i thought it would be easier~
good job!
Old Feb 23, 2009 | 07:50 AM
jayxx83's Avatar
jayxx83
yeah the original boot plinth isnt very deep and the new units have a plastic connector protruding on the rear. I thought at one point it wouldnt even fit, but luckily I managed to trim down the new units sufficiently to make it go, if just a little bit tight.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
xpunisherx
Aug 10, 2015 10:50 PM
OutMotoring
Aug 6, 2015 09:32 AM
